Question about Dometic Rooftop RV Air Conditioner
Condensation the evaporation that comes off the coach is acidic. it stains the side of the coach. is this something that needs to be corrected.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
First clean this up ., and add a drain tube to the bottom of the coach!
Posted on Sep 08, 2008
Why does water leak from underneath the car
Most likely condensation from the AC unit
Jun 20, 2016 | Cars & Trucks
How do I remove black water stains from normally oiled teak wood?
well 1st you need to determine what stains are made from ? if there a food stain then there most likely made from a grease of some sort , if this is so then denatured alcohol will take them off (with a bit of rubbing ) if there a rust or mildew stain then you'll have to use something stronger like muriatic acid (diluted w water 50/50) also note never add water to acid but instead add acid to water (yes it makes a huge difference) , this is dangerous stuff and all safe precautions need to be taken with it , this will also require all the teak oil finish to be reapplied after acid is neutralized with say baking soda and water (paste) and dried in air as this rough chemical will remove all the woods natural oils
while teak is a nice wood to have (beautiful looking) when something like this happens to it , it sure is a expensive wood to maintain
Oct 30, 2015 | Home
Water leaking in front driver's side and along back seat--where's it coming from and what can be done about it?
sounds like your ac drain is plugged up and condensate from evaporator core is leaking inside
Oct 09, 2017 | 2003 Volkswagen New Beetle Convertible
404A suction side-5 high side 275 whats wrong
TRY TO ACID WASH CONDENSER. AND CHECK IF YOUR YOUR EVAPORATOR MOTORS ARE RUNNING.
Mar 10, 2014 | True 49 cu. ft. / 1388 liter Commercial...
Air Cools well but after about an hour, water starts coming into the coach through the discharge air side. Unit does not freeze up but if I shut the unit off, the tray that holds the water drains quickly,...
Your evaporator is probably dirty and is blocking some of the air flow so the air has to move around the coil and starts coming in through the condensate drain holes. That stops the condensation (water) from draining out the holes because the air is pushing it back in.Try having the unit cleaned and that should stop that leaking.
Jun 27, 2011 | Dometic Rooftop RV Air Conditioner
Where does my air conditioner drain, is there a pipe or something?
Hello, most window air conditioners evaporate the condensate by the fan picking up the condensate and splashing the condenser, since the condenser is hot it will evaporate the water as soon as in comes in contact with the condenser.
May 24, 2011 | LG LWHD8008 ThruWallWindow Air Conditioner
Does the orifice, which needs to be installed in the inside unit of an a/c for a house, come with the outside condenser? I had an a/c system installed and an orifice was never installed. the original...
The orifice is the metering device inside the evaporator coil and comes installed from the factory in the coil itself. Some condensers do come with orifices taped to the side of the unit, but they only do that to ensure you have the right size orifice. Sometimes you will have a 3 ton evaporator and a 2.5 ton condenser. In this case you want to change the orifice so that it meters the refrigerant correctly. But if you have a 3 ton condenser and a 3 ton coil, which is normal, you don't have to do anything. So to answer your question, your coil already came with a orifice inside and nothing needs to be done unless there are two different sized units as described above. Hope I didn't bore you too much and helped you with your question!
Aug 19, 2010 | Goodman CKL60AR60 Air Conditioner
Water leaking into RV
If water is coming in through the filter grill, then your drain trough is clogged. Go up to, remove cowling, and flush trough drains out. That will take care of water getting inside. I like to use pipe cleaners and poke through drain holes on either side of the trough.
Excess water is also caused by poor air circulation and coils beginning to freeze up. All is well for a while, until the compressor finally turns off, then you turn fan off and water pours from above. So, while up top, also clean the coils of both the evaporator (located above and behind filter opening) as well as condenser. When cleaning evaporator, take care not to spray water into the inside of the coach. You should not need a special cleaning product unless the coils are very nasty, then use a non hazardous cleaner (you will get some on the carpet down below) such as Orange based. Also change your filter every 100 hours of the fan running (regardless of compressor) to minimize air flow restriction.
Aug 22, 2009 | Coleman Heating & Cooling
Dometic ac
remove the lower assembly and tighten the bolts that hold ac down to coach or pull shroud and check to make sure unit is not frezing up due to dirt
Jul 13, 2008 | Dometic 57915531 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
