Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia LCD TV is tripping the fuse in the house
I bought a new LCD TV Sony Bravia LCD HDTV KDL-40S4100. When I plugged it in, it tripped the fuse in the house, shutting the electricity in two rooms. On the same power outlet I used to have Insignia 42" LCD TV, with Xbox 360, PS3, Cable Box, and it never tripped the fuse.
With Sony it is happening all the time, I tried Power Surge protector, direct to power wall outlet.
Intresting thing is that I can watch TV, play video games for a long periods of time without any problems. Tripping of the fuse only happens when I connect more appliances in these two rooms and only in the moment I am pressing the power button on Sony LCD TV.
Can anybody give me some advice how to fix this, please?
    Scholar:
  • 38 Answers
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Posted on Dec 05, 2008
SOURCE:
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
Sep 06, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia 5 blinks
Hi Tradeboyle,
Please search 'Sony Bravia KDL-40S4100 40 in five blinks' on google and you will get several videos containing the solution of your problem.
Good luck.
May 12, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
Oct 05, 2013 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
How do you change sony kdl 40s4100 power supply
very easy there are just a few screws that hold the board to the chassis and then its a simple unplug the old boards wires then install the new board and replug the wires.
Jan 20, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
There is a big block in my TV screen covering 8 to 10 inches. I have a Sony Bravia, model KDL-40S4100, and i bought it in 2008.
if it is a black block, look in the menu under closed captions and see if it is in the text mode. if so change back to cc1 or turn off.
Aug 19, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL - 40S4100 LCD needs new LCD Screen. Where Do I find one?
You do know that the screen alone will cost you approx. 75% or more of the price of a new TV don't you? Good luck !
Jan 28, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Lost the screws that attached to the TV stand for KDL-40S4100. What type are they and where can I get replacement?
Required screw part number is as follows as per service manual of Sony KDL-40S4100 model..
7-682-973-49 SCREW, +PSW 5X16
and it is available in Part Store, click the link and I think TV needs 4 screws or so.
Thanks.
Sep 15, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Jun 18, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
564 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
