Air conditioner not working
I came in from out of town today and my house was 86 degrees. It was blowing air but it was not cold and the outside unit was not on at all. I checked the breakers and nothing wrong. I cut the breakers anyway to see if that would do anything and the results were backwards. Now the outside unit runs, but the inside unit will not blow air at all. What is the problem?
  • jweil Sep 08, 2008
    I have done that and it still does not run. I can hear some circulation noises but it is not blowing. Does this mean that the fan motor has gone out.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This is simple , turn your thermostat to fan only and not auto fan and see if it runs, if does then run it like this till a service man arrive, the fan motor for cool is gone out!
Posted on Sep 08, 2008
  • Richard Craft
    Richard Craft Sep 08, 2008
    CORRECTO!
  • Richard Craft
    But for now remove the fan door, and theres a fan switch in front of the door, unplugg the unit , tape the door switch close and tell the thermostat to call for cool and spin the fan motor with a probe, after it takesoff, add the door back turn the thermostat way down.If it cycles off, then you'll have to restart this again....
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
I just replaced the fan and the capastitor on an outside air conditioner unit yesterday. Today it was blowing so cold I increased the temp. on the thermostat. Now it is blowing 77 degrees air instead of...
The air being blown at the condensing unit isn't the air that blows inside. I seriously doubt what you said about it getting so cold. I believe that the wires to the capacitor were improperly installed, and your compressor isn't operating. Don't confuse the outdoor fan operation with compressor operation (they both share the same contactor as a switch). On the capacitor, the brown wire connects to fan, compressor attaches to "HERM" common attaches to the contactor. I didn't mention the colors of the common or compressor wires because they differ among manufacturers.
Aug 27, 2013 | Goldstar R1003 Air Conditioner
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Air condioner climbs to 86 degrees
First check your coil behind the filter. If this coil iss clogged the unit will over heat and cause the compressor to shut down. It sounds as if either the evaporator coil (inside) or the condensor coil (outside) may be clogged. If the unit is icing up on the inner coil then that coil is clogged or low on freon. I would think it would be cloggged instead of freon problem. To clean this coil you can go to the hardware store and buy a can of coil cleaner and use it following the directions The outer coil you would have to remove a/c from sleeve and take the unit outside. Using a water house flush the condensor coil from the outside in to remove debris.. These coils should look like a brand new car radiator when you finished cleaning. Reinsert the a/c back into wall sleeve after letting the water evaporate from the unit as to not spill water through out the area. Good Luck
Dave
Aug 25, 2009 | GE AJCQ08ACB Air Conditioner
The AC is on and it says it is 86 in the house and cold air is kinda blowing but it is HOT in the house.
Check outside unit to see if running if not check breakers and see if there is float switch inside the air handler inside. There is only so much you can do. Calla service tech for free estimate. Russ
Aug 15, 2009 | Heating & Cooling
The thermostat is set at 73... the air conditioner is running and cold air is blowing but the house is currently 82 degrees. I've checked the unit outside and there is no icing. I don't know what to do.
check to see supply air should be around 58F. 20* difference form supply air to return air if 58F my guess unit under sized air filter clean? when was the last time you had the unit tuned up?
Jun 20, 2009 | Heating & Cooling
Air conditioner is not cooling house. Seems to be blowing very little cool air through floor vents. It was 115 degrees today! Do I need to call a repairman?
At 115°F it is very critical that the condenser on the outside unit is perfectly clean and the fan operating. Try to shield the outside unit from direct rays of the sun. At 115° you could be reaching what is called critical temperature for the refrigerant. Yes, have it checked by a qualified service technician.
Jun 19, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
197 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
