Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Depenable care-Top Loader
When it starts to spin it shuts down.It starts up then tries to step-up speed and shuts down, like the start-run relay drops out??? Please help me my wife is looking at me very wierd
  • 39 Answers
Hi dannybridges
With the 5500 series it is usaly the motor comtrol board. i would get a tech just to be sure casue it chould be the main board at the top but i doubt it.
brent
Posted on Sep 16, 2008
I have a speed queen top loader washing machine it start with the washing sickle and the timer stop when it must start to spin or rinse and i replace the timer with a new one
There is sometimes a pause between wash and spin. This allows a little time to pump the water out before starting to spin. Do you hear the pump running between wash and spin?
Feb 01, 2017 | Speed Queen Washing Machines
My top load Bravos washing machine wobbles during spin cycle.
Most likely suspension rods and bushings need replacing. Also check outer tub ring. Sometimes it will break from beating on sides of washer, behind where water comes out.
Sep 30, 2017 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Depenable Care Gas Dryer has become very squeaky when the barrell spins. i took off the front panel and sprayed WD-40 on the backsides with the Plastic wheels and it went away for about 10...
Probably best to grease the wheels (called drum support rollers) rather than use WD-40 because that strips away the lubrication. It will also pay to check the drum support glides under the front of the drum. Worst case you may have to replace the support rollers.
Jun 26, 2011 | Maytag Dependable Care LAT9706
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Spin cycle problems
The machine is unbalanced.try moving clothes around.
Jul 04, 2010 | Maytag PAV2300 Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Today my maytag top loader had a string get caught under the agitator. It sounded like a jack hammer nad then started smoking. I shut it off, pulled the plug, took out the contents, plugged it back in and...
the agitator is held down by pins, the pins are attached to bracket, the bracket is attached to bearings and motor. Either the motor or bearings could be shot. Also there is a belt that spins the motor. IT is very likely that the belt kept spinning while agitator was stuck and burned the belt off.
Apr 07, 2009 | Maytag Washing Machines
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
