Air Conditioning settings
Our office is air conditioned, however my staff is complaining that it is either to cold or to warm. I have been setting the AC temperature at 72 degrees, some say 71 others say 73. What is your recommendations?
Thanks Ray Marshall
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Sorry, but this is a world old problem for ages, ever since there were fat peoples and skinny peoples.. A large person answer is they has more insulation and needs more cooling and a small person has less insulations and needs less air,,,See where I'm going with this? Our answer is to add a dummy thermostat-----(disconnect the control wires to the original thermostat and add the control wires to a new thermostat, out of sight at the return duct close to the unit----or-------add an adjustable grill over each cubicle so they can adjust it them selves to suit each person, and YES itcan be done ...!
Posted on Sep 08, 2008
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
Why is my dodge Dakota air conditioning compressor cycling on and off all the time? No cold air blowing
Possibly an faulty thermostat in the system or a blocked TX valve. have an accredited ac specialist shop test the operating pressures of the system
Sep 11, 2014 | Cars & Trucks
Air conditioner Blows warm air on drivers side but cold on passenger side
Make sure you have the settings to set both sides warm air, if not then you may need to find a tech person to help with the faults.
Sep 14, 2013 | Air Conditioning and Heat for Suzuki Aerio
Recharge the air conditioner
Instructions
    • 1Start the recharging process with any left over freon you may still have. Open the Civic's hood and attach the kit to the Civic's low side port. Then, set the kit onto a place in the engine compartment where nothing can move or shift once the engine has been cranked.
    • 2Start the Civic and let the engine run until it reaches its normal operational temperature.
      • Single Pressure Gauges for Indl., Commercial & Specialty Uses
    • 3Turn on the air conditioning to its coldest and hardest-blowing settings. Place a thermometer into one of the Civic's air conditioning vents and monitor how the temperature drops. Once the air conditioning's temperature reaches a level, constant degree, remove the thermometer.
    • 4Open all four doors on the Civic. This will allow any colder air generated to escape, and this will keep the Civic's air conditioning for accidentally cycling off while you recharge the refrigerant levels.
    • 5Turn the recharging kit's valve all the way down and let the refrigerant charge into the Civic's air conditioning periodically, shut the valve and look at the kit's gauge. This will allow you to monitor the recharging process. Allow at least one minute to elapse between refrigerant charges into the system.
    • 6Shut the valve of the canister, once it has become depleted. Disconnect the kit from the low side port.
    • 7Detach the hose, gauge, and valve from the empty canister and attach them to a new canister of refrigerant. Reattach the kit's hose to the Civic's low side port and continue recharging the system, allowing a minute between individual charges. The can itself can potentially grow very cold and hard to hold, even with gloves. Should this happen, wrap the can in a towel warmed in water. Ring out excess water before wrapping the canister.
    • 8Place you thermometer into one of the Civic's air conditioning ducts. Keep an eye on the falling temperature within the Civic's air conditioning system. The system is charged when the temperature hits 40 degrees. Also, within the engine compartment, the Civic's air conditioning aluminum tubing become uniformly cold.
    • 9Shut the recharging kit's valve and remove the kit from the low side port, once the system has been successfully recharged. Shut down the Civic's air conditioning, turn the engine off, and remove your key from the Civic's ignition. Also, shut all the doors
Jun 21, 2012 | 1998 Honda Civic
I have a 1999 323i BMW. The AC doesnt blow cold (on cool days it blows cool temperature but not common A/C Cold Air, Hot Days it blows Warm/Hot Air). The heater blows warm air but definitely not common...
First things first.....You must have the air conditioning system hooked up to an a/c system machine and then checked for leaks and also read low and high side pressures. If there are leaks then low Freon (R134a) content and low refrigerant oil can cause the a/c system to not engage the a/c compressor which basically means you will not have proper defrost functionality nor regular air conditioning. Most shops, when working with your air conditioning, will install air conditioning dye to assist them in locating leaks and is the first step in diagnosing all a/c systems. Post the findings after thw
Jan 21, 2018 | 1999 BMW 323 Series
Air conditioning is hot then cold for nissn altima
air conditioning is cold then it gets warm. compressor doesnt run very long
Jun 12, 2010 | 2006 Nissan Altima
Air-conditioning
Low refrigerant charge or a sticking blender door. Check the suction line for temperature. A cold tube means that the charge is fine.
May 12, 2009 | 2000 Pontiac Montana
Air conditioner staying on...
Many cars use air conditioning as part of the defrost function. Cold air will clear windshield faster than hot air.
Aug 01, 2008 | 2001 Honda Civic
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
