Question about SMC Barricade 7004
What should be the IP address of the computers connected to the router?
    Scholar:
  • 130 Answers
This question has already been answered. please view the solution at: http://www.fixya.com/ThreadView.aspx?thid=102186&prdid=234841
Posted on Feb 26, 2006
SOURCE:
How can I change my routers IP address?
You can assign Different Ip-address manually,Or use the Proxy to change the ip-address,by hiding the Original Ip-address or contact the ISP get the Dynamic Ip-address and Change the Ip-address,You can check the Ip-address at here
http://www.ip-details.com/
Jan 23, 2011 | D-Link AirPlus DI-524 Wireless Router
Can 3 computers (1 desktop and 2 laptops) share the same IP address?
No. Each device connected to a network must have a unique address so that data can be properly routed. If you want to share an Internet connection among several computers, you need a router. The router provides a single IP address connection to your service provider on one side. Then each computer connected to the router, wired or wireless, gets its own internal IP address from the router. As data comes over the Internet, the router takes care of getting it to the proper computer.
Dec 06, 2010 | D-Link DIR-615 Wireless Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can not access router setup page. IP is to be 192.168.1.102 , says can not find. This is the main computer on network, other's are wireless.
The number 192.168.1.102 must be your computer's IP address.If you want to access the router set up then You will need the Ip address of the router.
Is your computer connected to the router with the cable. if not then connect the computer to the router and check the IP address and default gateway on the computer.
Once you have the default gateway number use that number to open the router set up.
Generally the Linksys router IP address is 192.168.1.1.
Try this number.
Click Here for more information about the routers and network
Apr 22, 2010 | Linksys Wireless-G WRT54G Router
Router to Computer connection problem
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
If you are still not able to access it then press RESET button for 10 seconds it is in back side of router .Then you can access it with above default ip.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then you can DHCP there enable it then save settings and restart router.
Then set ip get automatic in your LAN proeperty set ip address get automatic.Then it get ip from router then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 02, 2010 | D-Link AirPlus DI-524 Wireless Router
Not providing valid IP addresses
make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
Jan 25, 2010 | D-Link DSL-G624M (0790069285783) Wireless...
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
What should be the IP address of the computers connected to the router?The IP address has to be 192.168.2.xx and the command to find out the IP address is ipconfig (Start -> Run -> "cmd" [enter] -> "ipconfig" [enter]).
Feb 19, 2006 | SMC Barricade 7004 Router
SMC Barricade 7004 Logo
737 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
