Question about Brother MFC-8840D All-In-One Laser Printer
Automatic paper feed
I get a paper jam when I copy using the auto feed. The paper being copied rolls down to the flat panel area instead of winding up in the tray on top. Please let me know how to fix, or do I need to take it in to a repair center?
Thank you
  • pmshouston Sep 08, 2008
    By the way, my machine is the Brother MFC-8840D.
  • 3 Answers
The narrow glass section at the left of the flat bed scanner glass is shaped concave to route the paper back up to the tray if you are using the document feeder. Right above this is a spring loaded paper guide that puts slight pressure on the paper as it is fed through. If the cover of the scanner is not closing completely it will miss guide the paper. I would check that there is nothing on the flatbed or in the hinge section that is keeping the cover lifted slightly. The hinges do extend for copying books, so it may have jammed in the up position causing your problem. Good luck!
Posted on Sep 14, 2008
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The canon runner s5000
1)u must verify which location of the first paper jam occur.
2)pick up unit > feeding >fuser unit> output delivery unit.
3)try to use platen glass for copying instead of using the auto document feeder unit.then u can narrow down the issue.
Sep 11, 2009 | Canon imageRUNNER 5000 Copier
How to avoid paper jams?
hi,the best way to avoid paper jam is cleaning.clean
first paper transportation area,second paper feed rolls in trays.send me result
May 31, 2009 | Canon PC-921 Black and White Copier
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Landscape copies get stuck
The roller may have something stuck in that area, something even as small as a peice of paper can continue to make it jam. if not, you may have to call the company to get a repair guy in... umm... or repairGirl?
May 17, 2008 | Toshiba 2060 Copier
Does the fault clear when you open/close? If it does you probably don't have a jam.
Does the machine begin to try to make copies, then stop-if so it has probably failed to feed off the tray, hence the jam message.If this is the case, pull out the paper tray, check for obstructions, clean feed rollers and try again.Are there "skid marks on the paper(indicating the rolls have turned?) If so rolls could be dirty/worn. If no skid marks, can you determine if the rolls did in fact turn? Go from there
Nov 11, 2007 | Office Equipment & Supplies
Brother MFC-8840D All-In-One Laser Printer Logo
147 people viewed this question
James Cagle
James Cagle
Jim Keysor
