Question about Samsung LN-T4042H 40 in. LCD HDTV
I have a samsung lnt4042h (bought it 2008) and it has worked fine until about a couple months ago, when it started making a clicking sound before showing any picture. the tv clicks about 5-8 times before showing any picture...audio works fine...the tv is only about 4yrs old...i've read similar reviews/complaints about this model...what is wrong and how can i fix it??
  • Jimmy Alaerts
    Jimmy Alaerts Feb 07, 2018
    I think bad capacitors bulld check de capaciteit in the power supply common problem with Samsung lcd tv
    Top Expert:
  • Samsung Master
  • 63,012 Answers
2008 until 2017 is way more than 4 years old . take it to a repair shop and get an estimate of repair costs
Posted on Nov 16, 2017
SOURCE:
  • 8457 Answers
SOURCE: samsung tv clicking sound
It ur power supply board it have components,is dead could be anythings,Capacitors bulbging happen mostly only on DLP Tv bacauce the FTB transformer,give high voltage for projection.Tries thes websites for replacement power supply board.Shopjimmy.com,Tv Repair World.com,Partstore.com or Ebay.com.
Posted on Sep 26, 2009
  • 610 Answers
SOURCE: Samsung Plasma won't turn on?
usually caused by the power supply board failing, very common problem.
Posted on Dec 10, 2009
  • 927 Answers
SOURCE: i have a samsung lnt4042h and it has worked fine
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
budmrtn
  • 11361 Answers
SOURCE: samsung 40" tv not coming on
I would check out the power supply module for bad caps with bulging tops. Check DC voltages at the output connectors, you should have 5, 12, 24V.
Posted on Jan 08, 2010
Testimonial: "This seems to be a common fault on these tv's. I probably wont attempt to fix myself even though the warranty has ran out. Thanx "
  • 15 Answers
SOURCE: Samsung PN50A550 Plasma TV started clicking on
hi i have replaced power controls boards in more than a few of these & this needs to b done by a expert .
Posted on Apr 11, 2010
Testimonial: "I figured it would be something along that line-Here in AK, repairs can be costly-but I'll get a pro. Thanks!"
Whining noise whendriving
Could be a front hub bearing or axle shaft.
Jul 13, 2012 | 2008 Dodge Grand Caravan
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
When I shut off the motor sometimes it wont start. I just bought a new battery 2 months ago. When I turn the ignition the starter doesnt even make a clicking sound. I can jump it or let it sit a couple of...
It might be your anti-theft alarm system. When the car doesn't start, is there a ticking sound inside the car? If so, hit the unlock button a few times on your keyless entry remote, until the ticking stops, then try to start the car. Hopefully this helps.
Mar 27, 2010 | 1998 Ford Explorer
I have a samsung lnt4042h and it has worked fine until about a week ago, it started making a clicking sound, and wouldnt turn on, the clicking goes on repeatedly until 5 secs after i unplug it. i kept ti...
Howdy,
Oct 21, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Clicking on Samsung LNT4042H
go here and fix it yourself for less than $10
www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
Jul 12, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Buzzing sound in kia
idler pulley
alternator bearing
power steering pump
or a belt
Jul 09, 2009 | 2004 Kia Sorento
Samsung clicking on and off but not coming on
The bang you heard was probably a capacitor. Since you are still hearing the TV attempt to power on, your power supply and it's fuse are likely fine, but if the capacitor was on the mainboard, the TV would require service unfortunatley.
Oct 14, 2008 | Televison & Video
Samsung LN-T4042H 40 in. LCD HDTV Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
