Question about Motorola Mobility M25 MP3 Player
Please help, it wont turn on.
I asked for help I have the idle problem wont turn on. I wrote it in the other screen. I no how this player works I would no If the player is locked or If the batt is dead, I need more than 2nd grade help!! can you tell me is there a upload that would fix this or does motorola have a tech support team I can speak to. Please help me alittle better than telling me to change the batt... THANKS.
Don't change the battery, but you have to take the battery out and leave it out for 2+ hours. Then put in a fresh battery and you are good to go. Mine does this every month or so. There is something about having no battery in it for a while that tells it to do something that cures this. Weird but I've been doing it for years.
Posted on Sep 18, 2008
My Mp3 player wont start up...
Problem Should be software -
Reinstall your mp3 player software. It will update your mp3 player.
Feb 01, 2010 | RCA OPAL M4001 MP3 Player
My zune screen wont light up
Mine started doing the same thing to me randomly this afternoon. It worked fine this morning but now the backlight wont light up no matter what. I checked the settings and everything.... it's the same as yours... I can barely see the screen its like it is idle and hasn't been touched. I've turned if off and on numerous times and nothing helps
Aug 17, 2009 | Microsoft Zune JS8-00001 Digital Media...
Locked
Have you tried to remove the battery. If not, try this remove battery, see if that works. If removing battery doesn't work you may have to reset your player. First remove battery again, but before you put it back on, slide or hold your power on button, keep holding it down then insert battery. The load-up screen should come on asking to reboot, cleanup , or reload firmware. Just reboot and see what haps
Feb 01, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Still does not work
What you will need to do is to update the firmware on the device..once you update the firmare it should be working fine...
I hope that helps
Please rate accordingly
Thank you
Computerrep
Oct 03, 2008 | SanDisk Sansa Clip MP3 Player
MP4 touch screen not working
my mp4 touch screen freezed and turned off. Now it wont turn on. please help
Sep 13, 2008 | Audio Players & Recorders
Blnk screen
my mp3 player is just showing a blank white screen. it wont turn on, wont turn off, my computer wont recognize it, nothing. whats going on and how can i fix it? thanx. anything will help at this point.
thanks dw dreamingmusic06@yahoo.com
Jun 01, 2008 | Philips GoGear HDD6330 MP3 Player
Computer not detecting
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
THEN, do the "Repair" in the Philips Device Manager
Jun 01, 2008 | Philips HDD1630 MP3 Player
Onix mp3 player
go to www.machspeed.com. Click on ONIX picture. They'll ask for you serial number (backside at the bottom), then follow instyructions.
The problem is that onix driver works just for win98.
Feb 06, 2008 | Audio Players & Recorders
My rio nitrus will not show anything on the screen
Ok. You have reset your device, there is a reset hole next to the DC-in hole. Then if it still not working then you have to ask for a new lcd screen/ lcd screen module. That means the LCD of your MP3 Player isn't working anymore. Good Luck
Jun 18, 2007 | Rio Nitrus MP3 Player
Motorola Mobility M25 MP3 Player Logo
89 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Unlockingcom
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
