Question about HP Pavilion dv9000z Notebook
Just won't work
I bought this computer 2 years ago and have never had a problem with it. I carried it with me on a trip 3 hrs away and used it. I didn't have any problems with it and when i got home it would not turn on. I plugged it into the wall and still nothing. I left it overnight and still nothing. Has anyone had this problem or does anyone have a suggestion?
    Novelist:
  • 130 Answers
Hi cwhaley,
This issue can be resolved by performing power drain on the notebook.
Here are the steps:
1) Remove the AC adapter and battery from the notebook.
2) Press the power button and hold it for a minute.
3) Reconnect the AC adapter, battery and try starting the computer.
Posted on Sep 09, 2008
Compresser will not start up Fan runs but compressor just kicks on and right back off
Low freon. As soon as the compressor starts the low pressure side drops below operating pressure. The freon carries oil that lubricates the compressor. the low pressure switch shuts it down to protect it.
Aug 24, 2014 | Dometic Rooftop RV Air Conditioner
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Second Chip key for 2005 Aveo won't work
assuming the 2005 model year stil uses viper security systems...the chip in the key carries a magnetic resistance frequency. if the chip is damaged or corroded the frequency will change and wont engage the igntion. you can either get another key made (about 75 dollars) or bypass the ignition lockout feature.
May 18, 2012 | 2005 Chevrolet Aveo
I have a Gateway GT5654 desktop that won't stop shutting down. I bought the computer brand new about 3 years ago, and I've never had any problems until now (I've even been running Norton 360...
it is possible that one of the three are going out on the computer, motherboard, harddrive, power supply, only a computer tech could tell which one.
Sep 21, 2011 | Gateway GT5654 Desktop PC
I bought an acer timeline x 4820 tg laptop 1 month ago which says it has got a battery backup of 8 hrs but it doesnot even gives a 5 hour battery back up . why?
The only reason is it will depends on the usage of your laptop. You can try to change the power settings of your computer so that it will last for more than 5 hours. You have 3 options: Power Saver, Balanced and High Performace.
1. Go to Control Panel
2. Hardware and Sound
3. Power Option
Thanks for using Fixya.
Jan 24, 2011 | Computers & Internet
Hi,problem is this If battery is in the laptop alone and at some stage charger is connected,charge light does not come on and battery continues to discharge. If laptop is then shutdown the battery...
dv4-1120us Notebook
BATTERY 101
if it runs with no battery , then its ok. see?
(does not prove internal charging chip is ok, see?)
but PC is ok on A/C line so use it. in A/C power.
learn too that letting any battery die flat , can kill it.!
best is to not walk away from any LT , running on battery only.
or risk damaging it. (the laptop tries hard to not do that but is not perfect science ,yet)
read up on cell reversal.. never flat line it on purpose and win !!!
next learn that batteries are short lived..
last a few years others months, that is what batteries do.
even car batteries can fail fast. (ask and old guy that)
all batteries are what I call "weak technology" "fails fast"
or imported from china, and are junk,. many are. so....
I always have 2 batteries, that way , having 2 good batteries
if one dies, its totally obvious, no? whats UP?
i have 2 batteries, too, so when on vacation, I dont go dry, see?
On some longer trips i carry 3, that is what laptops do best.
run with no AC jacks about.
May 13, 2017 | HP Pavilion dv4-1120us Notebook
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Can i use regular batteries and not rechargeable batteries on my kodak cx4310?
Yes, 2 AA batteries. Just insert them correctly.
They don't last as long as the CRV3 lithium battery pack though
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I bought the CRV3 battery and charger at Radio Shack and love it.
Bought it 3 years ago, still using the same battery after taking 1,000's of pics. I also keep a pair of regular AA's as a back up when I'm away from home
Dec 22, 2009 | Kodak EasyShare CX4310 Digital Camera
No USB Cord
Use a card reader.
Phanthip Plaza in Bangkok: There are plenty of shops in there that will be able to help you.
Mar 19, 2009 | Cameras
HP Pavilion dv9000z Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
