Question about SMC Barricade 7004 Router
How do I Enable Encryption or secure my wireless Network?
    Scholar:
  • 130 Answers
To enable encryption, you need to log into the router's configuration page: Click on Login -> Advanced Setup -> Wireless -> Encryption Think up a Hexadecimal code with the appropriate amount of characters for the level of encryption you wish to use (Hexadecimal means you can use any number between 0 and 9, and the letters A through F). 128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD EF 01 23 45 6D F9 64-bit encryption uses 10 characters. Example: 01 A3 45 F7 89
Posted on Feb 19, 2006
SOURCE:
I have this belkin and I want only myself to use this router, how do I blocked it from others?
Hi there.
I'm sure you want to secure your wireless network so only you can access it. There are many ways in doing this But first you have to change the router's default password to this You can enable the wireless encryption so you will be prompted to type a network password before connecting to your network. Lastly you can enable MAC filtering.
To enable wireless security click the link below: http://www.belkin.com/support/article/?lid=en&pid=F5D8231-4&aid=10177&scid=0 To enable the MAC filtering click this link below: http://www.corenetworkz.com/2009/07/enable-mac-address-filtering-in-belkin.html
Apr 05, 2011 | Belkin (F5D6230-3) Wireless Router
Linksys e3000 router. I am able to connect to the router without typing in a password. Under encryption on the computer its states "none". How do I enable encryption on the e3000? Thanks.
Open the web browser on your computer and type ''http://192.168.1.1". This address will open the configuration page for the router. When you are prompted for a login name and password to begin configuration, just type 'admin' in both boxes to gain access.
Enable WPA2 Encryption
Under the wireless security tab, enable WPA2 encryption by ticking the appropriate check box. This will encrypt all data that is transmitted over the network. If the data is intercepted by anyone, they will find it to be garbled data. To enable this setting, check out the 'Wireless Security' tab. Choose a long passphrase to use and write it down exactly, because you will have to enter this passphrase on every wireless device you want to connect to to router. (laptop, Wii, BluRay, iTouch, etc)
Feb 11, 2011 | Linksys E3000 Wireless Router
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
Wireless security via MAC address
I would enable WPA encryption and keep the MAC security on. Even though no other computers can connect due to the MAC security, without the encryption your network still looks wide open and it will tempt people to connect. At least if they see there is some sort of encryption on they will not even bother with trying to connect to it.
Feb 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Router Security
Once you connect to your wireless network and it ask you for a password or if you notice that your wireless network name has a lock on it or says it is secured. It means your wireless network is secured. Otherwise reconfigure your wireless to enable wireless encryption.
Jan 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need help dynex security sync wireless
according to the manual that i have, the model if the router that you have, DX-E401, is just a broadband router and doesn't have wireless capability. if that would be the correct model of your device, there's no way that you can enable the wireless encryption since it doesn't have wireless capability. but if you are really using a wireless dynex router, follow the steps below on how to access the router's page and enable the security.
access the router's setup page by typing http://192.168.0.1 on the address bar of your web browser (i.e. internet explorer, firefox etc). by default the username is admin, then leave the password blank.
you will be prompted with the router's page, now go to the wireless settings and look for the encryption field and enbale wpa from there.
if you are not sure whether your router has wireless capability or if you are using another wireless router just give me the exact model and brand then ask me
ciao!
Oct 03, 2008 | Dynex DX-E401 Router
Secure network
- access your web user interface by typing http://my.router (or the default address http://192.168.2.1) on the address bar of your web browser
- click on Basic Settings
- click on Wireless Security
- click on the Enable Wireless Security checkbox
- select either WEP or WPA in the Network Authentication list (Note: make sure that your wireless computers can support wpa if you're planning to use wpa. wpa is more secured than wep)
if you're going to setup wep, follow the steps below:
- select hexadecimal or ASCII characters as the Key Format, you can use either as a string of hexadecimal digits (character 0 ~ 9 and A ~F ) or as ASCII characters (any key on the keyboard)
- then select your desired encryption level from the Key Length list. it could be either 40(64)-bit or 104(128)-bit key length.
- enter four different keys in the Key1, Key2, Key3, and Key4 fields to store on your router.for 40(64)-bit encryption, enter a 5-character (or 10 hexadecimal digits).for 104(128)-bit encryption, enter a 13-character (or 26 hexadecimal digits) WEP key (note: you'll just need to enter the characters that you've setup on Key1 for all the wireless computers that you have
- click NEXT, then Save and Restart to apply the changes
if you're planning to enable wpa, follow the steps below:
- enter your pre-shared key. this key must match the key that is used by each wireless client computer associated to your router.
- choose a key format. this can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard)
- WPA Group Rekey Interval specifies how often the key "rotates" or changes
- WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports
then connect your wireless computers to your wireless signal using the correct wireless security (network key)
hope this'll help you.
Jun 08, 2008 | Dell TrueMobile 2300 Wireless Router...
Feb 19, 2006 | SMC Barricade 7004
SMC Barricade 7004 Router Logo
128 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
