Question about SMC Barricade 7004 Router
What are the possible default passwords for the router?
    Scholar:
  • 130 Answers
The password would be blank/admin/smcadmin by default. Blank password implies that you need to click on login without giving any input. But, if you have set a password on your own and not able to recollect it, try resetting the router.
Posted on Feb 19, 2006
SOURCE:
How to set up the password i put already the http://192.168.0.1 but its not openning my internet by that
It is possible that your router is on different default address. You can always reset router by pressing of reset button for around 10 seconds. Lot of router are then on http://192.168.1.1 by default. Default password can be admin or 0000 or 1234 (see router documentation. If you have good connection to router, when you ping 192.168.1.1 you will see response. If you can't ping (from DOS window: cmd).
When you going in you can always change this password on some tab (depend of router).
Aug 27, 2011 | Computers & Internet
Wnrb834b Setting security password
The default password for this router is password
User name : admin
Pasword: password
With the above username and password you would be able to log in to the router's home page (default Gateway- GUI)
Then incase you require you can change the router password or the wireless security key.
# If the above password is not working it may be possible that u had already set up/ changed the password hence you will have to Hard reset the router for this to work.
# How to Hard Reset ? = Insert a paper clip or pen in the reset hole located near the ports of the router for 30-30 second while the router is powered on
Hope this helps
Thanks.
Please Rate my answer/ or if you require any further clarification please comment
Jul 03, 2011 | NetGear DG834G Router
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
How do I get online with my ipod touch via my siemens router. I get a message ...invalid argument. How do I know what the router password is?
you will need to loginto your siemens router to look at the wireless section to see the password ITS possible the password is written on the bottom of the router - some manufacturers do this for default password security
otherwise post back the exact model and we can look up the default access IP address and user/password
Mar 18, 2010 | Computers & Internet
It seems like my password is reset... I tried all possible passwords I could have had but none of them worked... How do I get a new password to access my router?
On most routers, there is a reset button on either the back or the bottom. Unplug the router, push and hold that button for thirty seconds, then keep it pushed while plugging in the router. let it start up, and then it should be reset back to factory defaults. Use the default username and password to enter it and then put the password you want back in it. The default username is usually administrator or admin, and the password is usually password or just blank. If these combos don't work, do a search on the internet for default password for your make and model of router.
Nov 26, 2009 | Computers & Internet
Cant login never had username or password if i did i forgot
Depending on which revision you have there are two possibilities
Default Username is: admin
Default Password is: password
or
Default Password is: admin
If neither of these work - you may have setup a new username and password and forgot - on the router you will see a reset point - reset the router to factory defaults and the username and passwords above will now work.
If this helped you then please help me and vote kindly, thank you.
Oct 14, 2009 | NetGear WGR614 Router
Forgot the password so plz help me
You can reset the D-Link router to the factory default by :-
Powering up the router and pressing the reset button at the back of the router nest to the power socket.
open your browser and in the URL address box type in :-
http://192.168.0.1
The default login is admin and the password is left blank.
Sep 20, 2009 | D-Link (DIR-130) Router
How can I reset an unknown admin pw on Linksys RV042 VPN Router? I'm the new IT guy here, and I don't have the admin pw for our VPN router (and I need to provide remote access to a colleage working...
you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router Password: Admin
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router
Apr 16, 2009 | Linksys RV042 VPN Router
Passphhase
I'm assuming you set the password for yourself and have forgotten it? If that's the case, you'll have to start over. Press and hold the reset button in the back of your router for about 30 seconds. This will reset it to the factory default settings. Now you're able to use the default passwords. On older routers, the default username is blank and the default password is admin. On newer routers, both the default username and the default password are set to admin.
Let me know if this is what you needed. If not, we'll take it another step if possible.
Feb 15, 2009 | Linksys Wireless-G WRT54G Router
SMC Barricade 7004 Router Logo
170 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
