Question about Acer Aspire 3000 Notebook
Shuts Down After having the adapter plugged in, due to low battery. The laptop shuts off, not sure whats going on. Any help or suggestions would be appreciated, Thanks
  • kaycampbell Sep 15, 2008
    Hey I have the same problem, I bought a grid stand for it, taught it might be the overheating thing aswell, still the same thing. Maybe a virus aswell, I had it turned off for awhile, and when booted back on, the virus scan was expired so it may have loaded a virus.
    I am tryinmg to format but cant get it to boot from the system operting cd, I need help with that, if anyone could help me it would be greatly appreciated.
    Email me @
    kwd@nf.sympatico.ca
  • rich medrano
    rich medrano May 11, 2010
    What kind of laptop is it? How old is it?
    Brigadier General:
  • 5,158 Answers
Is the bottom of the laptop extremely warm ?
the fan and heatsink may need cleaning as it could be shutting down due to heat (thermal) issues.
Robert
Posted on Sep 08, 2008
What is wrong when AC Adapter is beeping continuously, and does not recharge laptop battery?
The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Nov 29, 2014 | Computers & Internet
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
Sep 13, 2011 | Toshiba Satellite M205-S4806 Notebook
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Shuts down right after start up, shuts off.
Hello there!
You have to check your battery meter. Then try to remove the battery and plug-in your laptop directly to adapter without the battery. Just to make sure if its going to start up when you power up your system using your adapter.
If you need further assistance, please let me know.
Regards,
fossildude
Nov 10, 2010 | Toshiba Computers & Internet
Emachine Turns Off
This is the best way to tell. If your system is shutting down on you by behaving like your shutting it down thru windows then it could be a spyware, virus trojan issue going on. If thats the case then run your virus program and see what it finds and remove it. If your laptop is shutting down on you where everything turns off right away with no lights, kind of like a power outage then go ahead and remove the battery and only use the ac adapter and see if that solves the problem. If it does solve the problem then you know its your battery that is the culprit. If your only using the ac adapter and the machine shuts off on you like a power outage with no lights then you know its a problem with the motherboard. With just the ac adapter plugged in, wiggle the cord near where it plugs into the laptop and if it shuts off on you like a power outage then you know its a loose DC Jack and it needs to be resoldered back into place. Hope all this helps.
Jun 12, 2009 | Computers & Internet
Looking for the New battery
There are really only two things to do. First, look into a replacement battery. A search on Google of "Satellite m105 battery" usually yields one or two sources of after-market batteries for around $50.
The second is only if your battery is a NiMH (nickel metal hydride) battery. In that case, you can create a power profile in the power or toshiba controls control panels where the computer does not go into hibernation or sleep. Go into the bios and make sure that the computer will not shut down on low power, and you may want to turn off the low power alarm. Then, making sure the computer is not plugged into the AC adapter, let it run until it actually shuts down from draining the battery. Then, don't leave it that way, get it back to a full charge. From then on, if you are working with the computer plugged into AC power from a wall socket, take the battery out.
A good source of info, though it's mainly about NiCd batteries, is: http://www.batteryuniversity.com/
Feb 02, 2009 | Toshiba Satellite M105-S3041Notebook
Toshiba not getting power
You may have completely drained your battery which it will need a full recharge before it will work again.
Oct 23, 2008 | Toshiba Computers & Internet
Acer Aspire 3000 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
