Question about SMC Barricade 7004 Router
How do I RESET the router? - SMC Barricade 7004 Router
    Scholar:
  • 130 Answers
You will have to use a paper clip or a similar pointed object to do the reset procedure. Hard reset: Insert the paper clip to the reset button and hold it down for 15 seconds, while the paper clip is still in unplug the power cord that goes in to the router, now wait for 15 more seconds and then give the power supply back to the router, again wait for 15 more seconds and finally let the clip go. You will see the router's LEDs flashing. If this happens it means that we have successfully completed the reset. Soft reset: Login to the router, go to the Tools menu, click on configuration tools and select the option restore router to factory defaults to reset the router.
Posted on Feb 19, 2006
SOURCE:
Can i reset the router back to the default setting
  1. Locate the reset hole on the router. The button will be on the back or side of the router.
  1. Leave the router powered on.
  2. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  3. Remove the paperclip.
  4. Wait approximately one minute for the router to restart.
May 10, 2011 | Belkin F5D8236-4 Router
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Cannot remember log in info
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
Cant log on to router
If you have forgotten your router's password, please follow the instructions below to resolve your issue.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router's web-based setup page. Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. Any settings on the router will be erased and the router's IP address will become "192.168.1.1," the username is still blank, and the password will be "admin."
To perform a hardware reset on your Linksys router follow the steps below.
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
3798-001.png Figure 1: Location of the Reset button of a Linksys BEFW11S4 router.
NOTE: If your router does not look like this, refer to the other images below:
4030-022.png Figure 2: Location of the Reset button of a Linksys WRT54GX router.
4030-024.png Figure 3: Location of the Reset button of a Linksys WRT54GC router.
NOTE: If the image of your router is different from the ones shown above, please consult your router documentation.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
Step 1:
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Administration then Factory Defaults.
4008-003.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Look for Restore Factory Defaults and select Yes.
4008-005.png Step 4:
Click 4268-009.png.
Nov 11, 2010 | D-Link DI 514 Wireless Router (DI-514)
The Cisco System logo just stays orange, I attempted to repair on my lap top but it won't let me repair.
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 09, 2010 | Linksys Wireless-G WRT54GS Router...
When my pc starts I get an error message concerning something missing in the dynamic link library. How do i fix this?
Try:
Resetting the Linksys Router to Factory Default
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 08, 2010 | Linksys Wireless-G WRT54G Router
My belkin wireless router is locked. How do I unlock it?
If you have forgotten the login password you can RESET the Belkin back to the factory defaults and configure it again.
THEN
Power up the Belkin and press the RESET button for 7 secs.
The default login password is blank.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 23, 2010 | Belkin (F5D7230-4) Router (587009)
How reset passsword.? router
Dear arliwave
It is easy to Reset Router than to locate its User name and password,
To reset your router, first of all switch on your router and press its reset button for 10 seconds. While with pressed reset button switch off power of router than after 5 seconds release the reset button. Now your router is reset to its default position.
At default its user name and password are " admin " .
For browsing to router site type http://192.168.1.1 or http://192.168.2.1 in your browser address bar.Enter by using admin as user name and password.
Thanks for sharing your problem with Fix Ya Family
Jul 29, 2009
Jul 11, 2009 | Zhone (6218-I2-200) Router
Forgot my belkin router password is there a way to reset it?
here you go, from Belkin's website
Reset the router to factory default Resolution With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings. SummaryThis article describes how to reset the router to factory default More InfoThis article assumes you cannot access the routers web interface.
Jan 26, 2009 | Computers & Internet
SMC Barricade 7004 Router Logo
128 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
