Question about Sony ICF-CD855VSIL Clock Radio
Power supply what is the output voltage of the power supply? I have to replace mine.
  • 10,594 Answers
If you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Posted on Sep 08, 2008
  • Shahid Electronics
    Shahid Electronics Sep 09, 2008
    I think it was complete answer of your question. doesn't it deserve fixya rate?
Samsung plasma hp-r4272c, i dont have VS volt output on main power supply board
Just replace the main power supply board if there is no vs voltage output.
Sep 21, 2015 | Samsung HP-R4272 42 in. Plasma HDTV
Tip
Cyberhome CH dvd-300
Power supply problems. There are many reports on this site for problems related to the cyberhome dvd player, one of them mine. Here is what I found. The dvd drive was ok it was the power supply that failed after a power surge. The power supply is a flyback power supply using the viper22 switcher by STM Microelectronics. you can download the specs with a schematic diagram simular to the one in the cyberhome unit. I wound up replacing the shunt regulator (TL431) Optical coupler (PS2561-a-1) , the 2200uf cap and the 1000 uf cap. this brought the 5 volt output to 5 volts which was the problem. The parts can be ordered from Mouser Electronics.
1000uf @ 10 volts PN UHE1A102MPD
2200uf @ 25 volts PN UFW1E222MHD
TL431 PN 512-431CLP
PS2561 PN 551-PS2561-1-A
Warning: The high voltage side of this power supply has 120 VAC and 161 volts dc when energized. thak precautions when measuring the voltages on the output. Good luck
on Oct 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Why is it displaying sc300 error?
High voltage power output error The measured voltage is not correct when the EGB measures each charge output (charge, development, image transfer belt unit, and transfer unit).
  • Disconnected or defective high voltage harness
  • Defective high voltage power supply
  • Defective EGB
  1. Check or replace the harnesses.
  2. Replace the high voltage power supply board
  3. Replace the EGB.
Jan 30, 2013 | Ricoh SPC242SF Colour Multifunction...
Supplied output voltage has hight frequency
Line-load-regulation to the TV power supply board is very low. Replace the main power supply board.
Jan 24, 2013 | Televison & Video
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
I have sony J21mn11. problem not power on only red lit led only.i check all the components on the power supply area and horiz. output D1878 all are good. there is power IC STR S6707 on power supply area. i...
If you have a digital tester or analog try to check the voltage reading from the power supply if high or low or no supply.Check first following voltage location and section. * Check the AC voltage from ac cord to fuse and before the bridge type diode. * Check the DC voltage after the bridge type diode.if normal voltage. * Then check the voltage into the filter capacitor to regulator ic.the power ic.If theres a input voltage in the power ic,check the output voltage going to harizontal output.If no output the problem is you power output.You need to replace it.
Jul 12, 2011 | Sony Televison & Video
No power even if I plug my DVD to power source
Good day.
Follow this procedure for trouble shooting.
  1. Remove the cover of your DVD player.Loosening all screw.
  2. Check the input voltage of the power supply 220v/120v AC.If don't have input supply that comes from the ac cord,replace it.
  3. If you have a input voltage supply comes from the power cord.Check the output voltage of the power supply such as 5vdc and 12vdc.
  4. If the you don't have output voltage from the power supply.Check the fuse if busted,check open/change value of capacitor,check power transistor (regulator)if shorted and leak/bulging top capacitor of the power supply board.If you found any defective parts replace it.
  5. If you have output voltage comes from the power supply.The problem could be the main board,replace it.
  6. If you already done this procedure,test it by power ON the DVD player.
I hope this information will be helpful.Thank you and good luck.
Apr 17, 2011 | LG Televison & Video
Ineed the voltage and connector polarity for the ADS TV ELite Pro
I just found one too, same situation... no power supply. Mine has box and all. On the back of the box, it reads:
Power Supply 7.5 VDC power adapter
It doesn't say what polarity, but judging from the board... I'm gonna' say + in the center. That's what I'm gonna do.
May 31, 2009 | A D S TV Elite Pro/w Remote (TEP-100R)
Testing the BN96-00249A power supply in an Akai PDP4294
You can get the schematics for the bn96 00249a smps here in pdf format. http://www.wimtv.be/techniforum/files/ps42p3sx_ch._d58a.pdf
Jul 23, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony ICF-CD855VSIL Clock Radio Logo
1,584 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
