Question about Sub-Zero 690 Side by Side Refrigerator
Side by side refrigerator has puddle under freezer
I have a Jenn-air JCB2388ATW without any water attached to it. We notice that every so often there is a small puddle of water under the front outside corner of the freezer side. Since we do not have water attached to the unit, it must come from de-frost or condensation. Is something plugged? Puddle of water on floor in front of doors. And I do not have an icemaker or water going to the refrigerator.
    Problem Solver:
  • 8 Answers
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Posted on Dec 12, 2008
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
Y jenn air side by side has water puddling out front left side, not under, I would also tie it ot the deforst cycle, maybe a clogged line, still cold, there is also some water underneath the lowest freezer...
There is a drain under the rear part of the freezer, see if you can see if it is blocked it may be fully of ice in the tube under it, if so turn off and pour hot water on it till the water drains out, put towels in the bottom of the freezer to collect this water, may take some time to get it cleared.
Apr 18, 2010 | Jenn-Air JCD2295HES Side by Side...
Sonetimes it gots heat and sometimes dont
Make sure your coolant levels are topped off. Now if you only get heat when the car is moving then you have a bigger problem like your water pump has gone bad. To check this, monitor the coolant level and check periodlically under your car for puddles of coolant when the car is parked for periods of time. If you return and have small puddles under the engine then it is almost 100% that your water pump has gone bad and needs to be replaced. If you dont notice those symptoms then have your t-stat checked out.
Jan 30, 2010 | 1997 Jeep Grand Cherokee
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
I have a jenn air JCD2389GES. Every day I'm getting puddles of water underneath the the unit. Our ice maker is turned off (broken for the third time)but the water line is still open to dispense water. We...
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Jul 09, 2009 | Jenn-Air JCD2389G Side by Side...
My jenn air side by side has water puddling in the bottom of the freezer section. I turn off the water supply going to the icemaker etc. still puddles. Is their a condensation line that could be clogged...
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 04, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Sub-Zero 690 Side by Side Refrigerator Logo
449 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
