Question about Toshiba 36AF41 36" TV
Remote sensor can you get to the remote sensor from the front of the tv or do you need to pulloff the back?
  • emman8 Sep 13, 2008
    Looks like this must be common with the toshiba 65hx81 had is since 2001 yesterday came back from dinner and have the blinking red light I am not that good with electronics I'm calling tv repair places now
  • 1,694 Answers
Chassis pull = front edge of PC board...resolder or replace sensor................T.
Posted on Sep 10, 2008
Tv volume control
Since it works when close, more likely the battery in the remote is running low, or you have some dust over the remote sensor on the front of the tv panel.
Mar 08, 2014 | JVC Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
What is a bad remote sensor
In all remote controlled optioned TVs have an internal circut section and a remotes sensor inside the front panel boad of that TV. The remote control hanset produces infrared rays of differnt frequencies, as we push each of its buttons. The frequency will be entirely different to one an other.
Infrared invisible rays are generated by an LED[ Light Emitting Diode], which fitted on the front side or the remote control hanset, and is directed to the infrared sensor window at the front pannel of the Tv, and will fall onto the infrared sensor inside it, and that sensor will convert these signals to digital format and gives it to the system control Ic to process.
The infrared sensor is a 3 leged element, which can be located inside the front panel of your TV, just back to the infrared window. It may get damaged, or may not get proper volttage. It shuld be replaced, if damaged, or find out the reson for the voltage drop, or no voltage condition.
Normally infrared failure is common. It is not so costly as you think, here in India we can get for about Rs25/= comes about 1/2 US Dollar. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-30HS420 30" TV
My Mitsubishi projection TV will not produce audio or video
Two things are involved to cause that problem, tv remote control and remote sensor in tv.
Upon verification of remote working, it would be confirm that remote sensor in tv is defective and need to be replaced.
Remote control sends infra red light signal to tv and we can not see that light with naked-eye, so need digital camera or cell phone camera to see it by watching remote front through camera, press any keys on remote, if you see infra red light is blinking in remote front that means remote is working and remote sensor in tv will be replaced.
If no light blinking on pressing remote buttons confirm that this remote is defective and buy new remote.
Let me know if you have additional question.
May 31, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Remote sensor in the TV
Remote sensor is locketed on pcb it an be replaced
May 11, 2009 | Televison & Video
Remote no longer works after opening rear of TV
I think blowing air cleaned the TV but Remote Sensor at front of TV got more dusty and now unable to receive Infrared signal of remote. That's my theory and can be confirmed by cleaning of Remote Sensor in TV.
Aug 25, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Sony KP-53HS10 TV Infrared remote sensor problem
Hey, I called the local Sony Authorized dealer/repair. He said the little microprocessor inside the sensor goes bezark once in awhile......soo.......unplug the TV from the wall when you go to bed and then plug it back in the next morning. It worked for me. The little gizmo resets itself.
May 17, 2008 | Televison & Video
the sensor for remote has fallen off its usually connected to a 8 inch wire which fell back into system pull the sensor wire forward the way to get into tv 3 ways front pannel pops off sensor is set at front
there the back of tv
then theres threw the
Mar 19, 2008 | Apex Digital GB5108 51" Rear Projection...
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Nov 14, 2005 | RCA P46924 46" Rear Projection Television
Toshiba 36AF41 36" TV Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
