SOURCE: i have brought a laptop
Samsung has a built in great power management. It will reduce power brightness to 50% or less if unplug from power cord. <<< it gives more times for power on the battery stays longer. BUT if you demand for some cases eg.PRESENTATION >>> go to CONTROL PANEL >>>power option >>> presentation. APPLY >>> OK
[email protected]
SOURCE: I Am Using Samsung Nd10
Usually, when you get the issues that you are having it may be your system is not compatable to Windows 7. You should be able to check to see if your system will work with Win 7 from the install disk itself or go to Microsoft website and check online. Sometimes the checks will show your system will work with the os BUT at a lower speed/performance until you brin the system up to spec. You may have to revert back to XP for better performance.
Good Luck
C2S
SOURCE: i have brought a laptop of samsung rv 509. i have
There are actually buttons on your laptop that are made for changing brightness.
Hold the "fn" key, and press the "Up" button while holding the "fn" key.
Do the same thing to lower the brightness, except hit the down key.
"fn" + "Up" Raise Brightness
"fn" + "Down" Lower Brightness
Thanks for using FixYa.
i am also having the same problem , i also own an rv 509...pls some one suggest the solution.
I Have the same Problem ("Posted by johnharrods on Aug 24, 2011"),
i didn't get any solution Yet.
Please Help Me.
Please johnharrods, if your Problem is fixed, Tell ME.
I need to know the solution for this problem.
or
Mail me
[email protected]
thanks
i have same here pls help me
