Question about Fagor Dishwashers
Error f8 Hi there I have a Fagor Innovation dishwasher. I get an error f8, related to the water pressure. I checked and the pressure seems to be OK. Any idea of how to troubleshoot it? Thanks and regards
  • 641 Answers
SOURCE: F8 Error
F8 code means that washer has not emptied out fully. Open the door,empty water manually, clear the filters and the drains. Close the door and then hold the start button,until it will restart. Good luck !
Posted on Jul 21, 2007
  • 159 Answers
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Posted on Aug 06, 2007
  • 210 Answers
SOURCE: "E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
Posted on Jun 07, 2008
  • 1314 Answers
SOURCE: Fagor Dishwasher
ok if you have a volt meter then remove the bottom kick-plate locate the water valve take the connector off the valve set the meter to ac volts plug the leads into the connector turn the timer to fill if your getting the proper volts to the connector then replace the valve if nor reply to me
Posted on Jun 12, 2008
  • 3230 Answers
SOURCE: Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
My Fagor dishwasher won't fill.
Check the water in-let electrovalve, could have dirt or the coil damage
Apr 30, 2014 | Fagor Dishwashers
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Whirlpool ADP8540 IX dishwasher - dishwasher starts then stop shortly afterward Error light flashing 4 times. I can restart by holding the start button but shuts down again shortly afterwards - Any Ideas??
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Need to check the inlet valve, the pressure pump as it seems to trip the controller unit.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Aug 18, 2011 | Whirlpool Dishwashers
Dishwasher begins cycle then switches to rinse - no water seems to be entering the washer
Most possible that the inlet line is clogged at the filter or that the inlet valve is struck or faulty.
Please make sure with a voltage check if the inlet valve receives the voltage to it, if not the program controller is faulty.
Finally check the water line pressure at the inlet.
Feb 04, 2011 | Fagor LFA086XL Dishwasher
Fagor Dishwasher
Jun 11, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
Dishwashers Logo
686 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
