Onkyo HT-R560 receiver
Keep going back to standby when turned on
  • 3 Answers
The unit most likely blew up a capacitor. If you look in through the slots on the top of the unit you should see 2 big black caps (C6901 and C6902) with shiny silver-ish tops. I should also point out that you probably flew up a 125v 8A (F901) glass fuse on the board that the AC cord plugs into. The glass fuse can be found at Radio Shack, but the caps are a bit more troublesome to find. They are 10,000uF 69v and thats just not a standard part, so you may need to up the voltage requirement and buy a 75v cap. Total to fix the amp yourself: Should be about $35 with shipping.
Posted on Nov 07, 2009
2 Suggested Answers
SOURCE: onkyo HT-R560
If you look at the manual, there are steps detailed to reset the receiver. This usually happens if the receiver becomes very hot. Try resetting and you should be okay.
The other problem is short circuit on the speaker wires. Check the speaker wires again.
Posted on Oct 12, 2008
What rca outputs should be used to connect an Onkyo RT 560 receiver's tuner to a Sonos system?
Hi Dennis, could you confirm the model number? Is it an HT-R560?
Thank you, Onkyo USA
Nov 08, 2016 | Onkyo Audio Players & Recorders
When in video mode only plays through one front speaker
Hi Richard please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Apr 01, 2015 | Onkyo HT-R560 Receiver
I have an onkyo HT-R560 receiver that won't turn on. the standby light light up and when you hit the power button you can hear a click-like sound but nothing happens. what should i do to fix my...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the
speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 07, 2011 | Onkyo HTR500 Receiver
I have a n onkyo av reciever ht-r560 only the front 3 speakers go on when im using it i know the rest work and are plugged in correctly because the volume tester outputs sound through it. Is there an on...
Your sound might not be working because the HDMI and optical audio inputs might not be working.
I made the mistake of buying the Onkyo HT-560 and in less than two years all of the HDMI video inputs started intermittently breaking. Sometimes when you selected the channel both the image and the sound would not come though.
Also the rear speakers stopped working from time to time and I have to run the setup again to get them to turn back on.
I am not sure that Onkyo was ready to introduce this technology, it has been a nightmare and my stereo is going to cost almost as much as I bought it for to fix it.
Oh and there customer service was no help, they just told to bring it to an "authorized service center for repair". They had also had no idea where there was one in my city it took them a day to get back to me.
The Onkyo HT-S5100 looks almost identical to the HT-560 not sure if they are different in anyway.
Stay away from Onkyo in the future! I know I will.
Sep 02, 2010 | Onkyo HTR500 Receiver
Onkyo remote code for Insignia Blu-Ray?
Unfortunately, Insignia can't provide a code. We recommend using your universal remote control's scan/learning feature to find a compatible code.
Feb 06, 2010 | Onkyo HTR500 Receiver
My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Dec 04, 2009 | Onkyo TX-SR501 Receiver
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
Onkyo HT-R560
Sep 08, 2008 | Audio Players & Recorders
1,239 people viewed this question
 Grubhead
Grubhead
