Question about Panasonic KX-T7633 Corded Phone
Main line shows solid red light
The main phone line shows a solid red light. None of the extensions are on this line, no phone is off the hook, etc. We are blocked from using this line because it looks as if someone is using it and it shows line busy on the display.
Evidently this happened before, but no one remembers how it was corrected. One person believes that it happened the last time when someone selected the line, pushed the "page" button and hung up. Not sure what happened this time.
  • Panasonic Master
  • 2,460 Answers
Fast fix is to turn off the power on the cabinet and power it back up.
Carl
Posted on Sep 09, 2008
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
Mar 04, 2015 | Panasonic KXDT343 Phone
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
    Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
    If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
    Carl
    May 11, 2011 | Panasonic KXDT333 Phone
    Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
    The phone doesn't like something it's sharing a line with.
    First, check to see if the extension number on each phone is different. You may have two extension 11's.
    Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
    Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
    Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
    Hi, When the phone rings into the office my phone is th eonly phone that doesnt show on what line the call is coming in to. One of the other phones is fed directly from mine and it shows it perfectly
    This is probably something that requires a technician unless you're familiar with ICD groups. The lines appear on buttons and your phone probably lights with a solid red light to show the line is busy, but you can't pick it up. By default, ICD code 600 is ring group 1, but you have to get access into SYSTEM programming to add your extension to it. The ring condition, immediate, no ring, or ring delay x rings is also part of the programming.
    Carl
    Sep 30, 2009 | Panasonic KX-T7630 Corded Phone
    Norstar M7310 Phone's Buttons Don't Work At All
    What system is this on? Sounds like the system is going downhill.
    Nov 18, 2008 | NorStar T7316E Corded Phone
    My GE instajack is not working. It had a greeen signal, now it has a red signal.
    Most likely, the extension unit cannot communicate with the
    indicator light is solid base unit for one of the following reasons:
    red • Base unit has yet to be installed. Install base unit. (Refer to
    the Set Up section.)
    • Extension is too far from the base unit. Relocate either the
    base or extension unit to another electrical outlet. If
    indicator light on extension
    unit remains solid red, reprogram the link code on extension
    unit
    Follow these steps:
    • Press and hold the button on the right side of the base
    unit until the indicator light changes to solid red.
    (Approximately five seconds.)
    • Release the button, then the indicator light will blink orange.
    This creates a new link code and places the base unit into
    program mode.
    • Follow steps (2) and (3) in the Additional Extension Units
    section for all extension units.
    • Press and release the button on the base unit to take it out of
    program mode. The indicator light will change from flashing
    orange to solid green.
    Oct 10, 2008 | Computers & Internet
    Night button and incoming calls
    The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
    Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
    Internal intercom
    If the person you are trying to reach is speaking to another internal extension, none of the outside lines will show in use. If their phone is not Call-Forwarded to any other extension (i.e. second extension or VM), you will get a busy.
    Feb 06, 2008 | NEC Electra Professional ETW-16DC-2
    Panasonic KX-T7633 Corded Phone Logo
    204 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
