Question about GPX D1816 DVD Player
Dvd player bad disc message
After inserting dics...loading and thrn getting bad disc message for all dvds
  • 2 more comments
  • matthews826 Sep 10, 2008
    Every disc I put in says bad disc. So one of the solutions for this was to clean it so I bought a cleaning kit but you put the disc in and it still says bad disc. You can't clean it if it won't play the disc. DOH! I'm about ready to throw this out the window. I worked fine for 3 months and I don't use it very often.
  • zion1024 Dec 20, 2008
    I dont understand this is a new player and its dirty already? nothing but problems every since i got this ( 3 mos)!
  • Steve Nordquist
    Steve Nordquist Jan 06, 2009
    Had an issue getting the tray to auto-retract, and now all DVDs ID as 'bad disc'; the lens inside is clean and the thing's generally responsive to the remote, but of course no DVD will play.
         I find by moving the laser head that the (visible!) diode is alive; but disc insertion and injection, as well as disc spinup is very very weak.  I find that the driver IC CD5888CB/GITcm19173N is very hot, as are at least two discrete transistors type D331 (SB550) next to that driver part.  Perhaps if these transistors are replaced, that will remedy the rest.... I could use some corroboration on what's hot in there and what is not.
  • advancemachi
    advancemachi Dec 16, 2012
    The problem may be the drive motor capactors are bad and the motor cant get going,put a dvd in and orient the lable ,close and wait a few moments ,open and check to see if the disc moved .
    Problem Solver:
  • 16 Answers
Your dvd head (lens) is bad
(1) it needs to be cleaned by a special fluid puted in the cleaning disc or
(2)it needs to be adjusted because it lit vey low illumination (light) during detecting the details of the disc. and this need a qualified technician ot adjust the variable resistor port attached in the lens assembly unit.
Posted on Sep 08, 2008
I have had a simikar problem and it turned out that my little son had put a DVD under the tray and it jamed the tray. I took the disc out and every thing is fine now
Posted on Jul 19, 2009
Hi
if you not have noting for clean used alchool and 1 qtip, if you clean and still no work can be also 1 little scratch in the lens, or equal in the 1° post the variable resistor
Posted on Nov 02, 2008
Dics is loading too long and then rejected
then there is a problem with the lens get a CD cleaner to clean the DVD lens and after that if the problem persist then you have no choice other than to change the DVD lens .
Jun 03, 2010 | Samsung DVD-R155
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Not playing dvds but only trying to load with no success
I had same problem, I resolved by this way..
After opening cover , I found one ribbon wire was not moving freely,(That wire is connecting Lens), After stopping DVD, by hand I have done it free (for easy moving), After that it started working properly.
~Sudhakar
Pune-India
Dec 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
GPX D1816 DVD Player Logo
3,921 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
