Question about SMC Barricade 7004 Router
How do I open ports in the Virtual Server? - SMC Barricade 7004 Router
    Scholar:
  • 130 Answers
You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows. 1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, NAT, Virtual Server. 3. Enter the port details and enable it as follows: Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx
Posted on Feb 19, 2006
I can not sign in
INSTALL VERSION 10.0.....,THERE ARE PROBLEMS WITH YAHOO MESS 11.
Jul 14, 2013 | Yahoo Messenger
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 127.0.0.1... [VIP Raw] Resolving host name 127.0.0.1... [PASSED] [VIP Raw] Connecting to Virtual IP server 127.0.0.1... [VIP...
Try this solution:
1. Open your Yahoo! Messenger
2. Click <Messenger> Menu and Select <Connection Preferences> and another window will open.
3. Under <Connection> choose <Connect directly to the Internet>
4. Click Apply and OK
5. Re-open YM.
Hope this may help.
Thanks & Regards,
(-_-)
Mar 24, 2011 | Yahoo Messenger
I can't sign in Y!M clicked troubleshooting and I got this Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the...
Bruno
Start your troubleshooting with a clean browser
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_cclean...
On the sign-in page click Messenger > Connection Preferences - make sure there is nothing untoward in the lower 2 boxes - if incorrect make changes using the drop-box options > OK
Copy this Yahoo secure site URL
https://www.yahoo.com/
Open Yahoo Messenger > Tools > Internet Options > Connection tab > LAN settings > Uncheck everything then check 'Automatically detect settings' and 'Use a proxy server' > Advanced > Paste the address in the secure box and type 5050 in the port box > OK
Sign in.
Hope this helps.
Mar 12, 2011 | Yahoo Messenger
Connect two tigerswitch 6724AL2 via fiber port
How do I open ports in the Virtual Server? pix.gif pix.gif pix.gif You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows.
Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows:
  2. Click on Login, Advanced Setup, NAT, Special Application.
Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y
* The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
Jan 05, 2011 | SMC TigerSwitch SMC8612T
Cant sign into yahoo messenger. Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw]...
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [PASSED]
[VIP Raw] PASSED *** 98.136.48.85 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0001' ***
Aug 10, 2010 | Yahoo Messenger
HOW CAN I OPEN A PORT TCP AND UDP IN FRENCH FOR DSLG604T V3.00
Exemple : Vous accueillez un web server sur un PC qui a l'IP address de LAN de 192.168.0.50 et votre ISP bloque le port 80. Nommez le Virtual Server (par exemple : Web server) écrivez l'IP address de la machine sur votre LAN (par exemple : 192.168.0.50 Entrez dans le port privé comme [80] Entrez dans le port public comme [8888] Choisissez le protocole (par exemple TCP). Assurez que le programme est placé à toujours Cliquez sur sauf pour ajouter les arrangements à la liste virtuelle de serveurs Répétez ces étapes pour chaque règle de Virtual Server que vous souhaitez s'ajouter. Après que la liste soit complète, clic sauf des arrangements au dessus de la page. Avec cette entrée de Virtual Server, tout le trafic sur Internet sur le port 8888 sera réorienté à votre web server interne sur le port 80 à l'IP address 192.168.0.50.
My French isn't good sorry.
Feb 15, 2010 | D-Link AirPlus G DSL-G604T (790069265662)...
Can't Open Ports in my Router
Make sure that you set or assign a static IP to your playstation first through your dlink. This would ensure that your playstation would have its own ip address and wont change each time you restart your playstation. Once you have that fixed then you could use the virtual server and set it to open all ports for your playstation's ip address. If it still did not work then instead of using virtual server, try setting your Playstation as a demilitarized zone. If that still did not work I think it would be best to contact your ISP.
May 31, 2009 | D-Link DI-704P Router
Feb 19, 2006 | SMC Barricade 7004
Configure the firewall
You can use the Virtual Server to forward an individual port to one of your computers. You cannot forward the same port to multiple computers. In order to configure the Virtual Server you need to know the IP address of the computer that needs the port opened and the service port number. The links below will help you find the IP address of your machine. If you don?t know which port needs to be opened, try checking the software manufacture?s support website for information on use behind firewall. Configuring the Virtual Server: Step 1 Access the device configuration by entering 192.168.0.1 in your web browser. Login with your username and password. The default username is admin and the password is blank. Step 2a If the port you need to forward is a common port, it will be under the predefined virtual server list at the bottom of the page. Click the pad and paper icon next to the virtual server entry you want to use. The Protocol Type and Service Port fields are preconfigured. Click the Enable radio button to use the virtual server. Enter the private IP address of the computer that will use the service port. Configure the Schedule as needed, then Apply your settings. Step 2b If the port you need to forward is not listed under the predefined virtual server list at the bottom of the page, you can create a new entry for your application. Click the Enable radio button to use the virtual server. Give your virtual server a name. Next, enter the private IP address of the computer that will use the service port. Then, select the Protocol Type and enter the Service Port. If you don?t know how to use Private and Public port assignment, then just enter the same port number in both fields. Configure the Schedule as needed and Apply your settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
SMC Barricade 7004 Router Logo
246 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
