Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic hdtv pt51hx42f
How to disconect high voltage (2 wires) so I can remove main board
  • Anonymous Feb 09, 2009
    can you help me with pt-51hx42f . flashing power lite. no picture.
  • 38 Answers
The wires some of them plug in and some are solder in if the are solder in that is the only way to remove them .but i would like to know y are u pulling the main board out anyway marty
Posted on Oct 13, 2008
What fault is it whenH97 comes on the microwave oven
could be serious or minor fault ,have an electrician or engineer measure the the ac current AT THE MAINS PLUG
1 = OVER 1 AMP,the magnetron or the inverter power unit is faulty
2= 0.8 AMP OR LOWER,HALF AMP,problem is dpc board or the wireing to it
Replacing,repairing or testing of the inverter power unit is best left to professional engineers with acess to panasonic test procedures high voltage high current = danger of death.
if 1.5 amps or so and magnetron suspect check with continuaty tester for open circuit fillament or wireing to
Jan 11, 2015 | Panasonic Microwave Ovens
Panasonic pt53wx53 led blinks once
unplug the set---where smoke something has burned.
I would with back off have a look---look at high voltage transformer and that area of board and pay special attention to C509 (brown cap in front of high voltage transformer about 2 inches---it will be marked with that C509 on board.
If it is cracked or burnt it is bad---these fail a lot.
If the set needs to be worked on it has a lightbox---about 8 bolts removed and entire guts or chassis comes out in one piece--can be powered up out of the cabinet.
Let me know if need more information.
May 29, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Powers up , has audio but no picture
Plasma sets have two separate power supplies; the main supply produces voltage for everything and may even produce a specific voltage for the high voltage required by the plasma display.
In your case, it is likely that the latter (HV) supply has failed.
This may be a separate board and if so, may be user replaceable since these are normally outsourced and just plugged into the set during assembly.
Removing the back of the housing, you are likely to see at least three boards. One of them (the main board) will have many components and most will be smaller in size. The main power supply will have much larger parts on it and the high voltage supply will likely be connected to it and have far fewer parts than the other boards.
It is possible but unlikely, that the main power supply is not providing voltage to the HV board for the display.
If replacement of the HV board doesn't restore the display, then it will be necessary to replace the main power supply too.
Aug 21, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Blurry picture. Red & green ghost. I am currently removing the circut board to replace the amplifiers. How do I remove the high voltage wire from y=the transformer
Not any amplifiers problems.The problem u having it known as covergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors pictures shadows or 3D look like pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board to solved the picture convergence problems.The Shop,will cost u $300-350 for parts and labors.
Oct 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Just yesterday, my Panasonic TH-50PX75U HDTV Plasma Television has only the lower half displayed. The upper half "flickers" but for the most part, dark grey/black. wtf
There are several possibilities here. Four different boards are involved in the horizontal scan of a plasma tv. The most likely order of failure for what you describe is; SC board, Su and SD, and finally the SS. These are Panasonic's names for what are more commonly known as the Y Main (or Y-Sus), the upper and lower Y buffer boards, and the Z main (or Z-Sus). Sorry I can't boil it down any further for you,... would have to measure voltages, etc.
Jul 09, 2010 | Panasonic TH-50PX75U Plasma HDTV
I have a Panasonic 53" PT-53x54- 53" turns on for 5 seconds then
It is very common for the high voltage tranformer or flyback to wear out and not provide adequate power to the tv. You can test them with an ohmmeter to see how much powrer is being sent to the main circuit board. You can get parts at tigerdirect.com
Dec 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
On my Kenmore Elite Bottom Freezer Refrigerator, the display on the left door reads ErCo and the ice maker does not work . Its less than 2 years old
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
IC replacement Question
Check this site for more info on a rebuilt board becuase I do no think Panasonic will have new boards.
Apr 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Removing D board
You can get the entire service manual emailed to you at the following link. It cost 10.99 and comes with unlimited free support to help you with your diagnosis your problem.
http://servicemanuals.vstore.ca/
Feb 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
