I have a Kidde model 0976 9V battery powered ionization smoke alarm. It chirps roughly every 45 seconds. I have changed the battery but did not cure the problem. Any ideas as to what the problem is? Thanks
  • Anonymous Oct 12, 2008
    It's just makes me crazy, i want to throw it in the trash.
Hi - I think I just fixed the problem for mine. I had the exact same problem. Literally just got back from the store with 2 brand new 9v batteries with an exp. date of 2013 (I made absolute certain they would be years away from expiring). I installed them, and I'll be damned if they didn't start chirping again. As I read the instructions one more time, it occurred to me that it was in hush mode. I pressed the "Push and and Hold To Test" button for about 2 seconds - not long enough to set it off. It hasn't chirped since, and it's been nearly an hour. Try that and see what happens. Good luck!
Posted on Nov 29, 2008
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
My Kidde Model 1285 keeps chirping even after I changed the batteries, any ideas why?
Be sure you are using a well known brand battery. The store brands, in my my opinion generally are not quite up to par. Try this and see if the chirp will stop. Thanks for asking me.
Dec 21, 2014 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My kidde AC smoke alarm I12020 chirps at night then come daylight it makes no noise
Most "chirping" is indicative of low batteries. Perhaps your smokes are improperly wired through a light switch? As to locating, try using a piece of tape over the sound port to change the sound; with these problems there are often more than one causing it. Check also to see if you have any CO alarms that were plugged into a switched outlet. Most of these also have battery backup. Good luck!
Mar 08, 2013 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
No, I didn't find what I was looking for, an answer to the following question. The Kidde Ionization Smoke Detector 1275 is electric only as it has no battery backup and it continues to chirp after the...
The 1275 does have a battery backup according to the manual on the Kidde website. Try this URL to get a copy of the guide:
https://portalgb.knowledgebase.net/al/15121/16372/article.aspx?aid=295779&tab=browse&bt=4&r=0.1818646
Aug 04, 2011 | Kidde 1275 Hardwire Smoke Alarm with Hush...
I just replaced 3 old interconnected Nortron AC 12W smoke alarm with 3 kidde direct wire 120V units- ( no battery back-up) when i turn the AC breaker on- all three Kidde chirp every 10 seconds. I ...
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
Jul 24, 2011 | Kidde 120-Volt Front Load Battery Smoke...
3 new Kidde i4618 smoke detectors were put in last week. Last night one of them began chirping. I went to the store and bought brand new batteries and replaced them and tested the units which all worked....
smoke detectors work by smelling the air across a radioactive anode which upsets the electronics and sets off the alarm
it can be set off not only by smoke but by heat and gasses in the air
the new and better product is a photo electric detector which alerts earlier and can be installed connected to each room and into the house power or they come with a 10 years lithium battery
It could be a faulty unit so take it back for a warranty exchange unit
Oct 30, 2017 | Kidde 4618 Firex Hardwire Ionization Smoke...
The unit was not chirping but I decided to replace the battery. After I put in the new battery the unit is now chirping.
Replaced another battery,brand new battery a must,press the test button,by letting it goes off like 30 or 40 sec. so it will detecting the new power of the battery.The chirping,will stop.
Nov 15, 2010 | Kidde 4618 Firex Hardwire Ionization Smoke...
Kidde smoke alarm won't stop chirping . I have replaced the batteries and nothing seems to fix the problem
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Mar 21, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Smoke alarm keeps chirping.
I am having problems seeing if you have any more data besides "smoke alarm keeps chirping." so I will ask; have you tried changing the battery?
Sep 06, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
I have the model 0916. It beeps every 40 seconds
Manufacturers recommend replacement every ten years. Could be dirty? Is it connected to the ac house power?
Aug 03, 2009 | Kidde 0914 Battery-Operated Ionization...
Computers & Internet Logo
468 people viewed this question
David Payne
David Payne
