Computers & Internet Logo
Posted on Aug 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi sir I have a problem with mu HP c61 Bluetooth : I am connecting my mobile with the laptop and i can not send or receive any folders and it is showing a yellow mark beside my mobile devise. could you please help me ?
Anonymous
Level 3:
  • Master 496 Answers
  • Posted on Aug 24, 2011
Anonymous
Master
Level 3:
Answers
496
Questions
0
Helped
111506
Points
1447
Make sure you have turned on the blue tooth in your mobile phone and it is on and ready in the laptop also. Make sure you have also installed the driver for the blue tooth in the Laptop.
Hi, My Samsung mobile is GT-C3303. I have problems in connecting to the bluetooth device on my laptop machine to transfer the music files. I have tried both 0000 and 9999 and 1234 but nothing is helping...
you have to pair your samsung phone to your laptop first before you can start sending and receiving files through bluetooth.
an option is, turn the bluetooth on your laptop on, then the bluetooth of your mobile phone on. on your phone, search for devices, then once you see the name of the bluetooth device of your laptop, tap it then choose connect or pair, you will be asked for a passkey (you can input anything try 0) or in some devices wait until a pop screen appears which will contain the passkey usually 5 to 6 digits. then click ok
another option is (i tried this using my samsung corby wifi and a samsung n150 laptop and it works just fine) make sure that the bluetooth on your laptop and phorne is turned on. on your laptop click on the bluetooth icon or click the file you want to send, then right click, then choose send to bluetooth, your laptop will then search for available devices, just choose your mobile phone then automatically there is a popscreen which has a passkey, then click ok. on your phone you will be asked to allow to connect thru the laptop, just click ok, then make sure that the passkey matches between your phone and laptop. (usually it is automatic, you just need to click ok) you should be able to send and receive files thru bluetooth on your phone and laptop
2helpful
2answers
I bought my son a blackberry curve 8250 a few days ago. I cannot send any files to his new phone via bluetooth, even though the phones do pair with each other. Please help!
When you send over bluetooth on a blackberry and the handset pairs you need to select the file type you are send and be in the folder to received. Once in that folder you need to click the blackberry key and select received via bluetooth.
I want to send a file from my hp pavilion dv6000 laptops by bluetooth to mobile but it give a error An address incompatible with the requested protocol was used.i am using vista. what can i do?
first you need to pair your laptop with cell. Open bluetooth in your cell,search the devices,select your laptop inside the bluetooth application in cell, assign a passkey and then you will see a msg in the laptop tray," a bluetooth device trying to connect, click here to connect". now click on the pop up in laptop, enter the same pass key and now you are paired. go to the file you want to send in side your laptop, right click on it ad select 'send to' select bluetooth and then you need to search and select your device inside the pop up menu, once selected, you can receive the file inside inbox of your cell.
cheers!
Sir I have Chang Jiang W007 Model mobile. I want to connect it to PC via Bluetooth and Cable. Please help. While connecting via bluetooth, i receive "DUN PROFILE DISCONNECTED'" MESSAGE. and while...
Sir I have Chang Jiang W007 Model mobile.. by accidently , the first SIM incoming calls barring password was blocked . also my phone charger unit also failed.. Is there is any solutions for my problems..pls send it to my email ID [email protected] advance thanks..
Sep 01, 2010 • Cell Phones
2answers
HOW DO I TRANFER DATA FROM THE MESSAGING FOLDER IN A NOKIA N79 TO ANOTHER MOBILE USING BLUETOOTH CONNECTIVITY.
hello,you can not send it from the messaging folder except you save it to another folder then you will be able to send it through bluetooth.simply because every content in the message folder could only be sent through sms or saved to another foolder.kindly go to options you will definitely see save to folder or you create a folder and move it there for you to be able to send it through bluetooth.
wish you good luck,
take care.
Apr 23, 2010 • Cell Phones
How to transfer theme to phone
Hello and Welcome to FixYa!
Here is a step by step guide for you:
If you want to use USB cable:
  • Connect your mobile phone with your PC/Mac via the USB Cable.
  • Start the Sony Ericsson PC suite and select “File Transfer”.
  • Navigate to the “Themes” folder.
  • Drag and drop your new mobile theme into the folder.
  • Select that theme from your mobile to check what we have installed.
If you want to use Bluetooth:
  • Activate Bluetooth on your mobile phone and your computer
  • Connect your mobile phone with your PC via Bluetooth.
  • Browse the content of your mobile phone with the folder view or simply send the theme file to your phone
  • Drag and drop the new mobile theme.
  • You can also right click your mobile theme, and select “send to Bluetooth” to your mobile phone.
  • Go to your Theme folder on your mobile phone, and select it to apply it.
I hope this solves your problem.
Please rate me if i was helpful.
Regards,
Waqar
Transfer pics frm moto razr v3 to laptop using bluetooth
Check your bluetooth connection with the PC and use Moto Tools suite to transfer photos . Other option is to simply make a connection with your PC and send photos one by one or mark all , send all to PC via bluetooth connection
45helpful
7answers
Bluetooth on HP Pavilion dv4000
i need bluetooth driver for hp pavilion dv 4000
2answers
Can't get any music or files sent to my nokia3110 via bluetooth
Hi lizzy2,
I am sure i know its solution.
There are 2 types of data storages in mobile phones. One is phone memory and another one is MMC.
In NOKIA s60s, all files sent via bluetooth is sent to the inbox.
But ur NOKIA is type of s40. i Think, so ur all music or files sent to ur mobile via bluetooth is received in ur folder "received files" in phone memory in gallery !
I m sure check out ur folder "received files". 1st go to gallery, and see there r many folders such as sounds,video clips, memory card, received files, themes. Go to that "received files" folder, and there is ur required files.
looking for ur kind feedback.
I m Sajan([email protected])
If need help, just send me feedbacks.
May 04, 2008 • Cell Phones
Grand Canyon Tech
Grand Canyon Tech
