Question about Thermador Cooktops
Intermittant/interrupted ignition device
Ignition onsome burners clicks&sparks, but won't light for minutes. one burner only lights with the knob in a certain position
  • 3 Answers
The problem here is that the port holes in the burners are probably clogged. Clean ALL burners by taking a toothpick and unclogging the port holes. As for the position problem, if you have independant igniters, as some models do, you may need to replace the igniter. Remove knob and remove igniter,(white rectangular item with two wires) remove wires and replace.
Posted on Sep 12, 2008
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
The thing that lights the burner won't stop clicking.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 30, 2011 | Maytag 30 in. CSG7000 Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
Burner with intermittent feature won't light once hot; spart OK - - no gas.
mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Feb 03, 2008 | Thermador SGS36GS Gas Cooktop
Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
Oct 13, 2007 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Cooktops Logo
231 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
