Question about SanDisk Sansa c240 MP3 Player
My mp3 busted
My sensa c240 busted... I can't go back to my menu, change settings, change song, play music. I can't even scroll my screen up and down! plz help
  • emhorsegal Sep 10, 2008
    Mine does the exact same thing!
    It is stuck at the screen when you first turn it on, which says "SanDisk".
    And then I can't do anything..it eventually just turns off.
I solved this problem just now.... remove the back cover of ur player, remove the battery and replace it and switch on... it works as usual...
Posted on Sep 26, 2008
Let it waste its batteries then plug it on your pc for it to recharge... weird but it work.
Posted on Sep 16, 2008
I solved the prob myself actually 2 days ago :) just let it waste its batteries then plug it on your cp for it to recharge. If its like mine, your problem should be solved this way, its wierd, but it work !
Please send a driver of scandisk sansa m240
Posted on Sep 12, 2008
Need to learn how to use a i-pod classic
Scrolling: move your finger clockwise to scroll up, and counterclockwise to scroll down.
Select/OK: center button
Menu: goes back to previous page. hold menu to go to main menu. you may chose what items you want in this menu under settings > main menu.
Music playback screen:
to fast forward, hold '<< or >>' OR press center button once, and use the dial. clockwise to go forwards, counter to go back. when done, wait, and the diamond will dissapear.
song ratings: Hit center twice then use the dial to enter amount of stars. is saved to iTunes next sync
Shuffle: three center clicks. can shuffle by album, or song. if it is off, it plays the playlist in order.
lyrics (If applicable): four clicks in is where you can view lyrics. if you do not have lyrics for a song input from itunes, four clicks will bring you back to the main song bar.
volume: simply rotate finger clockwise (+ vol) or counterclockwise (- vol). no Center button needed. must be in music screen. (aka, now playing.)
Hold switch: while active (orange showing) buttons and scroll wheel are deactivated to prevent accidental key clicks and volume changes.
For reference and more information:
http://manuals.info.apple.com/MANUALS/0/MA630/en_US/iPod_classic_120GB_en.pdf
these are some very basics I have written, I can definitely answer any specific how-to-iPodclassic questions.
-DF5
Oct 13, 2014 | Apple Griffin iClear Crystal-Clear...
Can't find the menu
if you pause the song that is playing the symbol next to the battery should change to a folder. when it does you press the mode button and it will bring up a menu called music mode. if select local folder at the top you can access all your music or delete the current song or delete all the songs
Jan 23, 2013 | GPX MW252S - 4GB MP3/WMA Digital Audio...
It wont format, it wont let me delete or even add songs? what do i do?
There are two to reformat your device. Just follow these instructions
From menu of your device:
1. Turn on your Sansa C240
2. From the main options menu, select " Settings "
3. Select " Format " and " Yes "
Formatting Manually:
1. Turn off Sansa C240
2. Slide the " Hold " switch on the bottom of the device to the " On " position
3. Press and hold the " Play " button. Press and release the " Power " button.
4. Hold the " Play " button until the LED screen displays the message " About to format device."
5. Release the " Play " button and press the " Next " button once.
Try these steps and let me know if you manage to reformat your device.
I could instruct you on how to reformat this device on your pc just post back.
If these solutions helped you.. please rate this answer and leave some testimonial too.
Thank you
Nov 17, 2010 | SanDisk Sansa c240 MP3 Player
Music player not play
Make sure you have MP3 files in your memory card. Click one of the MP3 file and open it directly, it should play with media player.
Now, open the Music player and press left select button and select Music library. In the Music library menu scroll down and select Update library. This will update your music player song list and it should work.
If this does not work and if there is any settings changed in the music player, select the Settings icon, and select Restore factory settings. This will ask you a password enter 12345 and it will restore the settings of your mobile to default.
Thanks
Jul 09, 2009 | Nokia 3110 Cellular Phone
Rizone 32gb. Only charging to 3 bars instead of 4 and this takes hours and hours. Can't find shuffle setting and can't drag and drop music. On screen it shows as gone in but when i check player music has...
To charge your player, with the player on OFF, connect it to a computer or other charging device. Then, after everyting is connected, then turn your player to ON. (For some reason, my player doesn't charge if it is already ON while being connected to the computer or other device.) It will charge.
This is the solution that I use for the music. Connect you player to the computer. Turn it ON after being connected. Go to FILE NAVIGATIONN. Copy your music there. (not in any forler, but as a separate entry in FILE NAVIGATION) Next, disconnect your player from the computer. (Use the SAFELY REMOVE HARDWARE feature for this.)
On the player, there is a PLAY button (NOT THE ONE MARKED "M", BUT THE ONE WITH THE RIGHT FACING ARROW WITH THE TWO BARS) next to the volumn button. After going into the FILE NAVIGATION menue, scroll down to the song(s) and/or music you want to move. Click the song using PLAY. You will see three options: MOVE, COPY, and DELETE. Scroll down to the MOVE option. In the main menue of FILE NAVIGATION, scroll down to MUSIC. Now click the "M" button (the one next to the button with two arrows and one bar). A screen will come up that says that the file is being moved. The song will now be in the MUSIC folder.
You could use the COPY or DELETE features for their respected funtions if you want to when these functions appear.
This is as complete as I can make it.
Jun 27, 2009 | Audio Players & Recorders
How to set a song to repeat over and over
It's in the friggin manual:
You can set your player to play songs randomly (Shuffle All ) or repeatedly (Repeat
One
or Repeat All ).
1 From the main menu, select > Play mode.
2 Press 3 or 4 to scroll up or down the options.
3 Press 2 to select an option.
While you are playing music, you can see the above active play mode screen.
The full manual is available at:
http://www.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
-Tha Mp3 Doctor
Dec 03, 2008 | Philips GOGEAR SA6045 MP3 Player
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Songs
The WMA songs that you have are DRM-encrypted, and they do not have "transfer rights" - as in, you cannot play them on your Mp3 player (either that, or they are only sample songs)
Solution 1: Upgrade your music service subscription
Solution 2: Convert the Songs to Mp3 format
Read up on DRM encryption - you can find more info in my 2-part "Tips & Tricks" under my profile - on song formats
Jun 20, 2008 | SanDisk Sansa c240 MP3 Player
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
Computer does not show MP3 player as connected and how to stop a song playing
If you installed the firmware update, you might have forgotten to change the device to MSC mode.. try going to settings>USB mode>MSC This should probably work.. to stop a song while its playing, click the |<< button while you have the screen with the current song. (you can pause a song on this same screen with the >|| button) If you have gone back to any of the menu screens, wait for a couple seconds and the player will automatically go back tot he song display screen so you can stop the song.
Dec 26, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
79 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
