Question about Refrigerators
Kenmore refrigerator side by side only cooling at the bottom
The refrigerator is a side by side and both the freezer and cooling cabinet are cold at the bottom. The top seens warmer. I put it through defrost manually a couple of times thinking my evaporator coil was iced up. I still have the same problem.
dididsaythat
  • 291 Answers
SOURCE: drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
Posted on Aug 25, 2007
dididsaythat
  • 291 Answers
SOURCE: Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Posted on Sep 04, 2007
SOURCE: GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Posted on Jun 25, 2008
mikedurland
  • 481 Answers
SOURCE: Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Posted on Jul 18, 2008
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
I have a Kenmore Cold Spot Side By Side Refrigerator/Freezer 106.52572202. The Refrigerator/Freezer was working fine until we moved it to the garage. We can hear the compressor working, but now the...
G'day - look to see if the unit has a cooling fan on the condenser - sometimes when you move a cabinet the hand truck can push up under the cabinet and jam the fan blade - or the tubing under the cabinet has been damaged
Sep 25, 2013 | Kenmore Refrigerators
Bottom of freezer side gathers water which eventually freezes. We think its coming from the ice maker
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Kenmore 57706 Side by Side Refrigerator
I have a kenmore side by side leaks from bottom of freezer
heatman101
Jul 07, 2011 | Kenmore 53642 / 53644 Side by Side...
The bottom freezer is leaking water. the bottom has ice on it.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water on floof, ice in bottom of freezer
heatman101
Jan 12, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
