Question about Hitachi 43FDX20B 43" Rear Projection Television
Info on iic's for this tv
Please send me info
    Genius:
  • 1,139 Answers
Hello doughball,
I am assuming you mean the Convergence Amps they are STK392-110s
Posted on Nov 20, 2008
Sony kv 29ls35e error codes
To enter into service mode to these sets,
* Turn on the Tv with its main ON/OFF switch at its front panel. [Standby Mode].
** Press the following buttons on the remote control in sequence. [ON SCREEN DISPLAY => DIGIT-5 => VOLUME --ve => TV].
The identification of errors within the [FE-2] chasis is triggered in one of two ways. [1] Busy. [2] Device failure to respond to IIC. In the event of one of these situation arises, the software will first try to release if the bus is busy, and then communicate with each devices in turn to establish if a device is faulty. If a device is not to be found faulty, the revalent device number will be displayed, with series of flashes of LED, which must be counted. Each time the software detects an error it is stored within the NVM.
No error => 00
Reserved => 01
OCP [Over Current Protection] => 02
Not used => 03
No vertical Sync => 04
IKR Error at power ON => 05
IIC bus clock and /data lines low at power ON => 06
NVM no IIC bus acknowledge at power ON => 07
Not used => 08
Tuner no acknowledge at power ON => 09
Sound processor error => 10
Jungle controler 8V error => 11.
Jul 22, 2014 | Computers & Internet
Panasonic PT-50DL54 problems
there actually was a class action law suit on these tv's due to the bulbs.
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
there is the list of codes so yours is 7. Hope this helps.
Keep me posted.
Thanks,
Lee
Jul 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Blinking green light
If the blinking is continious, the fault should be at its main digital board, as these blinks indicates a SDA - SCL probelm, says technically as IIC problem.
May 14, 2013 | Mitsubishi WD-73737 73 in. HD-Ready TV
Wont Come off Standby
IIC Bus line is busy. Should be a main Digital board problem. Check and replace it.
Oct 11, 2012 | Beko 324250WN 28" TV
My Panasonic PT-60Dl54J tv shut itself off and the power button is now flashing red 6 times. What has happened, how do I fix it?
This is straight from the service manual (I'm not sure what the problem is but it sounds serious):
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
NUMBER OF FLASHES CIRCUIT MICRO PIN
1 LOAD SHORTAGE 92
2 OVER VOLAGE 93
3 FAN SOS 94
4 MAIN 3.3V 88
5 LAMP DISABLE 61
6 GC3FM-IIC IIC
7 GC3FS-IIC IIC
8 GC3I-IIC IIC
9 COLOR WHEEL STOP 110
Dec 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Need to reset owner ID on a panasonic tx-32lxd
Service Mode Function
MPU controls the functions switching for each IICs through IIC bus in this chassis. The following setting and adjustment can
be adjusted by remote control in Service Menu
How to enter SERVICE
In main menu, move to choose sound menu, set BASS to MAXIMUM, and set TREBLE to MINIMUM.
Simultaneously press " i " button on remote control and DOWN button (-/v) on the TV set.
Exit with off switch on tv.
When you next switch on TV it is as brand new giving you the option of setting pin number and user ID.
Mar 05, 2009 | Panasonic CQ-VD7500U 7 Wide LCD/DVD/SD/TV...
Need driver fgor xp pro
hi,
This is where I download most of my drivers... click me
Happy FIXYA! Peace!!!
Aug 20, 2008 | ATI 3D Charger (4 MB) PCI Graphic Card
Power Button Blinking Red
Talli,
The number of blinks, called error codes, is crucial in determining what's wrong with your unit.. In this case the color wheel is faulty and needs to be replaced. In that unit the color wheel assembly is Panasonic p/n# TXFEN01RP4S and is available from many sources for about $390.00 plus shipping.
There are some companies like Tri-State-Module that have taken-up rebuilding color wheel assemblies but I can't be certain that this is one of the brand/models they support. If you can have it rebuilt you might save about half the price of a new one...
For your edification in the future here are the blink codes for your Tv:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
If I can help any other way just let me know...
Good Luck!
Bill
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
PT54DL50
There is a problem in your 3.3v main line and until corrected it will not power the lamp. This isn't usually an expensive repair but one that a shop will need to do since most of the work will be in trace testing voltage and signal using a scope.
For future information only here are the blink codes for this unit:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
Hope this helps!
Bill
Sep 13, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Hitachi 43FDX20B 43" Rear Projection Television Logo
20 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
