Question about Kenmore 15516 Mechanical Sewing Machine
Jammed thread. It's happened about five times already, three last night. I have never made anything with the machine (or any) but I know that's not supposed to do that! I've threaded the machine and I'm ready to stitch. The bobbin thread comes up and the directions tell me to pull the "tail" to the side, so I do. I work the foot pedal and about three stitches later it stops. I open the shuttle race cover and pull the bobbin case out, behind it is a huge mess of tangled thread. I cut away a tangled thread and try to thread the machine again and when I start it up again it gets tangled. I have to be doing something wrong, any idea on what it is?
  • Rave-Panduh Sep 09, 2008
    I'm sure it should have worked but I really think it only made it worse. I'll try again tomorrow.
    Problem Solver:
  • 4 Answers
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Posted on Sep 15, 2008
Machine just locked up, no obvious thread/needle issues, can't find answers in book...safety function on, Help! Someone said take bottom off and look for thread? Only used it a few times, but out of...
Can you turn the hand wheel at all ? If not, something is jammed tight somewhere.
Have you removed the bobbin from the bobbin case and cleaned thoroughly around it, removing all lint, dust, loose thread bits ?
If that does not help, can you try taking apart the shuttle assembly, which the bobbin fits into ?
Sometimes you may get thread wound around in these parts and it causes a jam. Please, observe how the parts of the shuttle assembly fit together so you know how to put it back together. There may be a small lever or pair of levers that must be moved to allow the parts to be pulled out. There aren't many, usually two or three pieces.
It's very useful to snap pics.. of it the way it looks before you touch it, and then each step as you take it apart, so you have a guide to putting it back.
It's also possible a gear is jammed. Most machines allow you to remove the upper casing and bottom casing. You'd have to take out some screws to do this. If anything is jammed between gears that you can see, remove it carefully. If you have to use a tool to pull out something jammed, take care not to damage the gear teeth, as that's a big repair job and often not worth the expense compared to buying another machine, sadly.
Mar 04, 2015 | Brother PC-420
Brother sewing machine jammed?
take bobbin out...look in case in machine and pull any loose threads...you have to sew very slowly so this does not happen...the books don't tell you that!!! Make sure bobbin itself is neatly wrapped and thread is out where it is supposed to be once inside case.
Apr 04, 2013 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread gets jammed
Is it forming a stitch at all? Do you have your needle set properly and are you certain it is the correct size. it sounds like the hook isn't catching the loop formed by the needle. If changing the needle doesn't help. it might be time for a clean and adjust.
Dec 14, 2012 | Kenmore Sewing Machines
My sewing machine gears jammed.
One or more of the bushings is seized, the machine needs to disassembled, the bushings removed, cleaned, re-lubricated. Not something you can do yourself.
Apr 07, 2010 | Baby Lock Espire
Singer FUTURA CE-250 beeping at startup.
you have a bit of cotton blocking a sensor or lever. normally the one that tells you ran out of cotton.
Oct 03, 2009 | Sewing Machines
Elna tavaro won't stitch
Sounds like either some thread jammed in the bobbin area, or possibly it got knocked out of "time"-as you know a sewing machine is just that-a well tuned machine that has movements that have to occur in sequence. Were you sewing anything heavier than normal? I have knocked my Janome out of "time" twice by sewing something too heavy for the needle or the machine in general. I have also had thread wad up under the bobbin. Re-alignment or whatever they call it is not real expensive but would result in some downtime for your machine.
Oct 23, 2008 | Sewing Machines
Where to purchase pressure foot (same one that comes on machine when purchased
If you go to the Simplicity Homecare website and click on Accessories, that will take you to their e-store for parts. I broke an upper looper needle on my SW432 last Saturday, ordered on Wednesday, and already have the replacement!
Aug 28, 2008 | Simplicity Serge Pro SW432 Mechanical...
Kenmore 15516 Mechanical Sewing Machine Logo
626 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
