Question about Acer Aspire 3680 Laptop
Acer 3680 wireless laptop
Our neighbor has evidently got a wireless device. It seems to interfere with our getting our laptop on the internet through our own wireless router. How can we block out this signal?
  • Acer Master
  • 13,433 Answers
Hey, heres a good video about the topic
Let me know if you need anything else.
Posted on Sep 08, 2008
Aspire 5580/5570/3680 series ACER laptop was reformatted and the OS was changed to windows 7 from windows xp. wireless connection cannot find any signal
Check that you have the proper drivers installed. The device may not be compatible for window's 7,in that case, get a pcmia wireless card that is compatible.
Mar 09, 2010 | Acer Aspire 3680 Laptop
My Acer Aspire notebook keeps losing its internet connection. I have used 2 different routers and the signals were strong on both, so it's not that. I've also downloaded what I took to be the appropriate...
If you are using the supplied Acer program to setup your wireless, I would suggest removing the program. In most cases, removing their software does not remove the drivers, and thus, Windows Zero Configuration will take over the wireless.
WZC, in my opinion, works very reliably and has solved this type of issue in the past, although it is not the only reason for disconnects. For instance; a weak signal and a lot of interference from neighboring networks can cause your wireless to become unstable.
If this doesn't fix your connection issue, you may have an issue with the wireless card itself.
Jul 29, 2009 | Acer Aspire One AOA110-1588 Notebook
Need drivers for laptop mainly network drivers
You can download latest device driver for all acer aspire laptop models including your aspire 3680 (both XP and Vista drivers available) @
May 28, 2009 | Acer Aspire 3680 Laptop
Want to download wireless internet to the system it is rum by windows 2003
What you need first is to install the wireless driver for your wireless card in your computer. If you don't have one you need to purchase a wireless card.
Then read the following info to decide what type of Internet access you require.
Wireless connections to the Internet can be achieved by several methods and it depends upon the method of delivery by the Internet Service Provider in your location.
The most common is by DSL and cable, the modems that are used with DSL and cable connection can have a built-in wireless router. Your computer will require a wireless card to connect to the modem/wireless router and the range is restricted to approx. 100 ft depending where the wireless router is located within the building.
The laptop's wireless card can be a built-in device or a plug-in device eg a PCMCIA card or a USB device. and these can also connect to a wifi hot spot in locations such as McDonalds. Star Bucks etc.
There is another method that can connect into the Internet that uses a USB wireless device that connects to a G3 network, bacically a type of mobile transmission and the device is locked into a specific Internet Service Provider. This method gives a wider mobile range (even across states) of connecting to the Internet but usually at a higher cost.
Basically you need to see what the Internet Service Providers offer in your location. Beware of the costs of the various plans they offer in broadband speed, their download limits and the penality for exceeding the limits etc.
When you decide which method you choose, you need to consider setting up your wireless network securely to prevent unauthorized access.
May 08, 2009 | Acer Aspire 3680 Laptop
Can't turn on wireless connection on my wife's acer aspire 3680
Ran system restore which brought back the drivers for wireless
Apr 08, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 bluetooth
I want acer aspier 3680 bluetooth & wireless laptop driver
Jan 18, 2009 | Acer Aspire 3680 Laptop
Cant connect wireless on acer 3680 internet provider says its the computer my acer laptop not picking up wireless internet
you may try:
1) check a wireless switch is on, and wireless light is on on your laptop, if not on go next
2) go bios check wireless setting is enable. if 2 not fixed go next
3) go windows check wireless driver that easy to see at right down bar show a icon of wireless. and then check control panel system and go hardwire management network adapter, you can find the wireless card status. if all above normall
4) recommend reinstall your windows.
Dec 26, 2008 | Computers & Internet
Acer 3680
for Aspire 3680, the button is close to headphone jack. it's a switch.
but make sure your wireless card is detected and enable in device manager.
Jul 21, 2008 | Acer Aspire 3680 Laptop
I upgraded my Linksys WRV54G firmware from 2.39.2 to 2.39.2e and completely lost internet connectivity
hi there,
have you tried to reset your wireless router so that the default settings are being used, then try reconfiguring it again for your Internet connection.. then try to connect wireless again ... sounds like your router may have lost its settings which happens for some firmware upgrades.....
Wireless Interferences
Neighboring wireless networks or any appliance that operates on the same frequency as your wireless device (e.g. 2.4 GHz) may cause interference and therefore may affect your wireless connection and signal.
Common sources of interference are:
  • Neighboring wireless networks
  • Microwave ovens
  • 2.4 GHz cordless telephones
  • Bluetooth devices
  • Wireless baby monitors
To solve the problem, change the channel and SSID on your Access Point. Preferred channels to use are 1, 6 and 11 since they’re considered non-overlapping channels.
May 01, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
