Question about Philips Magnavox 51MP392H Rear Projection Television
TV no-picture Turn it on and just a click. I hear crackling. Removed the back and see acrhing in the end of the middle tube. The other two glow. I can see the arching inside end of the tube. Bad Tube? Want to know cost to see if this thing is trash or not. Thanks
    Genius:
  • 1,139 Answers
Hello cooperjason,
You may have a short between the grid and the cathode of one of your tubes. This is repairable if you happen to have a CRT tester. It can remove the short and allow you to balance the three tubes once you have repaired the problem. There is information on the web about how you can clear the grid / cathode short by using a charged capacitor across the grid and cathode pins of the CRT.
I would suggest, though, that you get a qualified TV repair person to do the work on this TV. Since the voltages involved are rather dangerous.
I hope this helps,
Thank you
Shuttle83
Posted on Sep 14, 2008
I have a zenith projection tv model r56w36. It won't stay on. When I remove the back panel and turn it on, I see a bright flash coming from the middle bulb on the right side of it where It looks
better be very careful here, if a pop or flash near one of the three crts or picture tubes there is serious voltage there.
the tubes each have a sealed wire delivering at least ten thousand volts to each tube===I have heard this before. likely what you have now is the seal they place where the wire enters the tube (2nd Anode) is arcing.
tube has to be removed to get at and reseal that--not a beginner or doit yourself job.
Note: if you keep turning it on sooner or later it will destroy other parts.
Sep 03, 2012 | Zenith R56W36 56" Rear Projection...
Sounds could be heared upon switching on of the set but the screen has no raster (means total blackout as if the unit were off. a small red LED located @ the front panel continuously blinks just like the...
Since you said the the pictur tube is glowing, your EHT system is OK.
After selecting a channel if sound is alright the TV up to signal
detection is working OK.
The problem now could be in video amplifier circuits. Check the grid
voltages of the picture tube.
Or switch off TV, and check the resistance values of the resistors
connected to the picture tube pins. Replace the defective resistor.
Check after removing one end of the resitor as it will misguide you if in circuit.
Aug 23, 2010 | Televison & Video
Magnavox plasma television will not turn on, makes
Relays clicking noise you hear.....change caps..you might see visible signs of CAPs being bad....swolen,,, top ready to explode etc.
May 19, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
I can hear the tv but cant see it
Video circuit problem.
Check whether you get a filament glow in the picture tube neck. It will be faint. If OK,
Just place your hand near the front of your screen, when TV is on. If EHT is generated you will feel the static effect on face plate on the glass. Your hairs will drawn towards the picture tube. No EHT, no such effect will be there. Refer trouble shooting procedures.
Mar 29, 2010 | Sylvania 6419TA 19" TV
Turns on but no picture
It appears that one of the CRTs has a short in it. It can be repaired with a CRT tester or with a capacitor charged up and applied to the grid and cathode pins of the CRT having the problem.
I would advise that you have a qualified TV repair Technician do this.
Thank you,
Shuttle83
Sep 08, 2008 | Philips Magnavox 51MP392H Rear Projection...
Flashing Standby/Stero light and No picture.
How good is your picture when it did come ? Is it as good as it once was ? Or is it alittle washed out. If it is washed out the picture tube is weak . Sometimes turning up the screen control alittle would solve problem but if you turn it up too much you would have faint white line running diagonally. Now if you think the picture was good before you this problem video circuit would be your suspect . Jungle IC or something in the RGB circuits . Good luck
Feb 27, 2008 | Sony KV-35V35 TV
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Tv has a big black in yhe middle,does that mean that the picture tube is going out
no that is not the sympton of picture tube failure. please give the details of your problem so we will get you solution.
Oct 07, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 51pw9303 51 in. Rear projection. no picture. has audio
To be honest if you have never worked on a set I would reather you contact a tech in your area. You can do more damage that it may already have by being a fierst timer or having no experience.
Aug 19, 2007 | Philips 51PW9303 51" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
