My smart drive 9 is trying to fill with water put keeps stopping like its blocked
Repekah! It's Andre! Are you from Rewa!??????? My email address is andrepritchard25@gmail.com.
Posted on Sep 23, 2013
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Posted on Jan 11, 2008
  • 1294 Answers
SOURCE: F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Posted on Feb 08, 2008
jsrock516
  • 5911 Answers
SOURCE: washer fills and won't stop just overfill's
The water level is controlled by the pressure switch. It will be located behind the load level selector knob inside the operator console. The way MOST pressure switches are designed, they will have an electrical connector plug and a rubber hose attached. Unplug the washer and remove the back panel of the console and verify if the plastic air hose is still attached to the switch. It is common for this hose to fall off over time due to vibration or develop cracks. If the hose is not attached, the pressure switch will not detect the change in pressure from the wash tub as it fills and the water will not shut off. The tub will continue to fill until it overflows. The same is true if you have a bad electrical connection. Remove the connector and check the terminals to make sure they are clean. If any of these preliminary checks do not work, replace the pressure switch. If your washer is not configured this way, please post back with your model number so I can attempt to verify. I hope this helps you.
Posted on May 15, 2009
stephanos18
  • 144 Answers
SOURCE: water filling issue
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
  • 19 Answers
SOURCE: Freezer Ice Maker Won't stop filling with water
The water solenoid at the back where the water line attaches to the fridge has failed
Posted on Jun 29, 2009
Fisher and paykel Smart Drive 9 excellence 7.5 washing machine wont fill at the start it just makes sounds like its trying then starts beeping?
the water soleniod has went bad pull out washer look to where water lines hook up to it turn of water to them then remove hoses unplug machine remove the soleniod valves make sure you write down the wiring order and hose placement on something get new valves replace rehook water line turn on water ect.
Aug 20, 2014 | Washing Machines
Fisher & Paykel Kelvinator Smart Drive 601. Machine does not complete full cycle. Stops at most stages and beeps. Seems to have trouble with water intake. Hoses have good water pressure when...
the magnetic switches may be warn. in hard water areas they can block up and stop working. you may need to change them or take them out and stick them in some vinaga and see if it will soffen the hard crust off the inside of them out.
Oct 06, 2013 | Fisher and Paykel Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
Smart drive washing machine not filling properly?
sounds like you do have a solenoid problem undo hoses from back of machine check the filters are not blocked also check at the tap end to see if filter are cleare if all filters are clear most likely you will have to replace you inlet valves assuming there is no problem with pcb board.
Mar 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
When filling my F&Paykel washer the water is not a constant flow, it is filling in 'spurts', ie stop/start/stop/start etc...... I have tried cold, hot & warm water, all combinations of temp are...
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. Mca0824@aol.com
Apr 30, 2008 | Washing Machines
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
