Question about Toshiba 36AF41 36" TV
Toshiba 36A41 remote not working
Bought a new original and it does not work either. Before that I tried new universal remotes and they did not work. Any ideas?
Ed I have the 36af41 and have the same problem
  • ja185318 Dec 09, 2008
    I have the same TV and just started having the same problem, only mine is intermittent. I think it's just a matter of time before it flakes out all together. I've tried numerous remotes and all work sometime but most of the time not.
  • sam hensley Jan 03, 2009
    i...r sensor is out. Is easiest access thru back cover or thru and how thru front strip that houses i...r sensor, channel, and volume controls, etc?
Replace I-R sensor in tv
Posted on Dec 29, 2008
I have a toshiba 36A41 and a rca universal remote
Check and replace the infrared sensor inside the TV. It's faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 19, 2014 | Televison & Video
Remote control senser failure in tV
It can be replaced. Contact any service tech:.
Mar 23, 2013 | Toshiba 36A41 36" TV
Bought a 42pc3d-ud Lg Plasma tv from someone without a remote so i bought a new remote. i do i program it
This is a universal remote u bought wright?Check ur tv remote owner manual follow the instructions and program in ur tv universal remote codes for ur tv universal codes.If none of the tv universal codes of ur tv model will work,return it.Try website like Remotes.com to buy the tv original remote or very close compatible to the original one.
Jun 04, 2011 | LG 42PC3D 42 in. Plasma Television
Purchased an RCA universal remote (RCRH02B) and the codes listed in instructions don't work. After programing (or trying) the device with all the codes individually, the TV will turn on and off,...
Consider that you may have a bad remote. You never mentioned why you bought a new remote. Did the original remote quit working? If so, the problem may be with the TV.
Jan 04, 2018 | Toshiba 13A24 13" TV
The volume doent work when using the remote. I have tried the cable remote and the original tv remote and the volume works at times but less and less.
Try imputing a different toshiba code into each of the remotes. 0156, 0060, 0154. If that does not help, then unfortunately it is your tv.
May 14, 2010 | Toshiba 36A41 36" TV
Remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Dec 15, 2009 | RCA Universal Remote Control
What code?
try 0164 - works my toshiba
Aug 26, 2008 | Televison & Video
Remote Control not working
you can easy check if you existing remote really work just look on the IR led with a digital cam and u will be able to see the led flashing
Feb 05, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Remote Sensor Repair
Before condemming the infared remote receiver, make sure that you have tried and original toshiba remote control. Sometimes universals do not always work. If you do have to replace the (IRR), the main circuit board or the button assembly must be removed. The part is soldered in and has only three wires. The approximate cost of the part is around $20. You local service center would probably charge you $80 to $100 for the repair. If you have already tried a number of universals, the chances are that the(IRR is defective). Also try the code search on the universal remote sometimes this will work. Scrivitron
Jun 19, 2007 | Toshiba 36A41 36" TV
Toshiba 36AF41 36" TV Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
