Question about Samsung Televison & Video
When switching our tv on by the mains on a morning the standby light flashes but when pressing the power button it does not switch on until switching the power off by the mains and then back on again,it only ever works on the second try,what would cause this?
    Problem Solver:
  • 16 Answers
May be your tv has a problem on memory ic so let your technician replace it.
Posted on Sep 08, 2008
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
My technika lcd40-920 tv wont turn on standby flashing blue to red i held power in 30secs n stopped flashing but still wont turn on why some one said its trying to update but not sure can u help
How long have you had this TV? If it is under 12 months, get it fixed under the guarantee. If you have an extended warranty, use that to get it fixed.
I would suggest that you switch everything off, remove all the cable from your satellite box or games console and everything else, then switch off at the mains and unplug the set.
Now press and hold the power button on the TV for 30 seconds.
Now plug the TV into the mains again and use the TV button to switch on the set. If the lights continue to flash, then it's a repair job. If the lights are steady but there's no picture, then switch it off using the TV button and reconnect the aerial cable first and try it again.
Once you get a picture displayed, you can begin to reinstall all of the other cables until everything is working again.
Apr 13, 2015 | Televison & Video
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
Lcd tv light flashing but no picture or sound
If you removed power by turning off power itself to the set instead of turning it off by turning the set itself off---that is not a good thing to do.
When power is restored a surge can and likely hit the power supply in your set---time for a tech or shop to open it---I suspect they will find the standby or main power supply is damaged or now bad.
Dec 06, 2012 | Bush Televison & Video
My TV standby light keeps flashing for 10minutes then TV will not switch on. Does not respond to remote or the buttons on the TV panel. Please Help
If the standby light flashes but the set does not trigger or come ON, then it is confirmed that this is an error to signal there is a failure of the main section- drivers to the display.
Now the processor is working as it displays the flashing but the feedback error shows that the circuits is not powered due to this protection.
So disconnect the main power+B and check for short in each individual power circuits.
Check for faults on the driver IC or look for suspected capacitors , leaked or top blown.
Also finally check for dry solder joints, solder all suspected joints.
Apr 08, 2011 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Samsung tv wont come out of standby
Not expensive but very hard to find the exact problem.
Both are not the same problem.
Mostly, your case related IR module problem.
the other below, yours are poewr board or thermostat problem.
Jan 14, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
