Question about LG Cell Phones
Getting an error that says car kit on phone - LG Cell Phones
  • 4 more comments
  • dancreguy Sep 09, 2008
    my phone says car kit and i cant get it off the setting. i cant talk on it at all
  • GradPsych Sep 26, 2008
    Phone says "car kit" is on. How do I turn this off?
  • Anonymous Oct 05, 2008
    same thing! cant hear ringtones or calls
  • dave469 Oct 07, 2008
    I have the same problem. Was plugging charger in when it happened. I'm thinking maybe a pin got bent???
  • Leshia Nov 27, 2008
    I have the same exact problem. My phone wont even let me call anyone. It says Car Kit on the main screen.
  • Anonymous Mar 26, 2009
    I had luck just removing the battery for a few minutes and putting it back in. Phone reset itself.
Mine said car kit and I kept reading it was because it got wet, and my phone didn't get wet. I noticed a little corrosion where I plug the phone in starting to form and I rubbed a little off and the car kit on the main screen went away.
Posted on Jan 22, 2009
For my phone, i also couldnt hear and ringtones and couldnt call anyone. then i looked in the bottom of my phone where the charger goes and there was a little pin that was bent so i took a pair of tweezers and gently moved it back into place and it went back to normal in an instant.
this worked for me, but you might have a different problem.
Posted on Mar 06, 2009
I accidently left my phone outside when it starting raining (2-5 mins) i retreived, wipe and dried it off. I did not bother to use until about 2 hours later when I notice that its not working. I then notice the car kit mode, I follow some advise of looking at the bottom where the charger is plug in. I took my charger line and (without plugging to A/C outlet) I played with it by plugging in the phone and move it up and down, and in an instant the car kit mode disapper. work also for me.
Posted on Dec 28, 2009
I cannot get the galaxy ace to automaticaly connect to my car hands frre kit ( Parrot )
The parrot car kit varies, there are about 10 different types of the parrot car kit and the connections varies slightly. Just follow these steps to connect ur galaxy phone to the car kit.
For this model of the parrot car kit,after the installation on your car,ensure the car is on
Parrot CK3000:
1. Start the car and ensure the car kit is on.
2. Activate Bluetooth on your phone, and search for Bluetooth devices.
3. Select "Parrot CK" from the list.
4. Enter 1234 on your phone when prompted for a password or code.
5. The Parrot CK3000 will sound a beep when connected to your phone.
Your phone has now been paired with the Car Kit and is ready for use.
For other models of the parrot car kit,repeat step 1 & 2 above and for step 3, u select the model name like "parrot EVOL" for the CK3000 Evolution model.
Aug 30, 2011 | Samsung Cell Phones
Unable to pair phone
Is it able to see the car kit but you don't get the pin code to connect?
Try sending an MP3 to the Parrot kit. I couldn't even get the Parrot BT in my car to ask for the BT password numbers but found out to try sending an MP3, which will fail by the way, and it asked for the password finally.
There was an error in my case, but then the phone asked to connect to the Parrot again and the pairing worked.
There is an issue with newer Nokia phones, something I will be thinking about next phone upgrade.
Feb 14, 2010 | Parrot Par Ck3000 Evolution Ck3000...
I have an LG LG-VX8300 cell phone. It's stuck on ''car kit'' and I can't use it. I have no idea how it got on ''car kit''. How do I fix it?
I can almost guarantee that if you look closely at the contact pins in your charging port, you will find they are either slightly (or extremely) corroded, or bent out of shape. Try cleaning the contacts with a toothbrush and isopropyl alcohol.
"Car Kit" is a device that you plug into the charging port of an LG phone for hands-free use. If you are not using a device of this nature, and still see "Car Kit" displayed, it means that you got the phone wet or otherwise damaged the charging port.
you can also try resetting the phone
#1) press soft key for menu
#2) then press 0
#3) you'll have a service code prompt, type 000000
#4) then type 2 (it should be field tests)
#5) then type 4 (clear errors)
#6) choose yes for clear errors
#7) press clear once
#8) type 1 (Service Prg)
#9) choose ok soft button (in the middle) all the way through until the end. Then the phone will reset.
Nov 02, 2009 | Cell Phones
Nokia 6220 wont pair with parrot vm3.18????
I have the same phone and car kit.
Sep 17, 2009 | Parrot Par Ck3000 Evolution Ck3000...
VX4400 Cell phone locked on CAR KIT, How do I get it off CAR KIT?
Remove the Battery for a few seconds and reinstall. It may take a few times but it will reset
off "CAR KIT" if you do it a few times.
Jun 18, 2009 | LG VX4400 Cellular Phone
Nokia 5800 will not pair
Hi. Same car same phone same problem. After about 200 tries it works. I did nothing special the time I got it but it would seem that if you keep trying it will work. Very strange if you ask me.
Jun 09, 2009 | Parrot Par Ck3000 Evolution Ck3000...
LG Phone has Car Kit Error. Didn't Get Wet. Can I Clear it
Dear customer,
                     To Remove “Car-kit” error there are few ways:               What worked for me as suggested by chemist  is using Calcium Chloride (CaCL2) as a drying agent since it pulls moisture out of the air, and according to Verizon, this car-kit error is caused by exposure to moisture. For the average person, you can find this in the form of “Prestone Driveway Heat Concentrated Ice Melter” (or other ice melter – check ingredients).
1) Pour about 1 cup or so of CaCL2 in a small Tupperware container.
2) Place a sheet of paper on top of the CaCL2 to protect the phone.
3) Place the phone on top of the paper so as not to allow phone to touch CaCL2 (this is important).
4) Place the lid tightly on the Tupperware container.
5) Allow to sit overnight.
In the morning, the “car-kit” error was gone! Yay! I could could hear my callers, they could hear me, and I could hear all my ringers.
                         Other suggestions that  might work for you are.
         Car Kit
 To remove errors from phone:
#2) then press 0
# type 8 (FCC test)
#9) type one (pcs)
#10) type one again (set channel) (mine shows 426 I don't know if theres a different channel for each phone.)
#11) press clear 3 times and the phone will reset.
                       FOR RESTTING
Enter "Menu"
Select "Settings"
Select "Security"
Enter "Lock Code" - Will default to last 4 digits of phone number or "0000" unless changed.
Select "Reset Defaults"
Press "Ok"
Plz rate this solution.. thank you..
Apr 09, 2009 | LG VX8300 Cellular Phone
Have a htc diamond touch mobile phone and wont connect to the pioneer cd-btb100 hand free car kit or the blue ant car system in my other vehicle. however the blue tooth seems to work with computer or...
sir,ur problem seems quite irrelevant ,so the simplest way to solve ur problem is ,buy a user friendly handset like nokia,sonyericsson n i assure u,u'll n'er come across such kind of prob again in future.
Sep 05, 2008 | Cell Phones
Lg cell phone vx3450
This is an old post but in case anybody searches and finds it...The infamous "car kit" mode on LG phones is a problem I had. Your service provider will claim the phone got wet (they will look at indicators in the battery compartment and on the battery itself that turn blue in the presence of moisture. Trouble is, they will eventually turn blue just from humidity even if the phone wasn't given a bath). Search the web; there are one or two forum threads with many suggested solutions (such as resetting error codes in the service menu, scrubbing out the battery connector with a toothbrush, plugging/unplugging the actual car kit connector, etc.). None of these suggestions gave a permanent fix (YMMV) for me and I eventually bought a new phone.
Dec 10, 2007 | LG VX3450 Cellular Phone
Cell Phones Logo
1,105 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
