Question about Epson Stylus Photo R220 InkJet Printer
RED LIGHT FLASHING
I HAVE THE SAME PROBLEM, TWO FLASHING LIGHTS , AND I PAID MY SUBSCRIPTION GENO
  • Anonymous Oct 22, 2008
    hi both my lights are flashing on mine found the reason why from epson, the printer has to have a service. cant get mine to do anything, epson said i have to take it into a local place that will give give it a service and replace the parts that get wear and tear to them while using it. i told them it is a load of .... , they just want more money. if there is another reason why it would do it let me know thanks
  • SPANNIES Nov 06, 2008
    hI WERE DO I GET THE SSC PROGRAM TO RESET MY PRINTER ???
Hi there, i had the same problem but now it is solved by installing this program SSC on a windows and i reset the printer from there, and it worked.
Posted on Oct 30, 2008
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Red Flashing lights
Hey,
Remove the cart ridges, restart printer, does the lights still flash? restart printer, place cartridges back in, make sure the tape is removed from the cartridge. also you can try cleaning the contacts.
So after you have connected the carts again, restart printer. how is it?
Thanks,
Ekse
Sep 08, 2008 | Epson Stylus Photo R220 InkJet Printer
A red light keeps flashing and the screen says error when it comes on
If you have a red light flashing then you have one of the following: 1 red light e74, 2 red lights - overheating, 3 red lights GPU and the CPU, or 4 red lights you need to plug the av cable in.
For the 1, 2 , 3 red lights you can send it in to get it fixed or reapair it yourself with a good guide
Oct 26, 2009 | Microsoft Xbox 360 Console
Plays games then stops when red lights start flashing
How may red lights are flashing?
1 red light normally E74 error message on screen
2 red lights overheating
3 red lights the GPU and the CPU have overheated.
4 red lights is the AV cable not plugged in properly.
You can fix the 1, 2, 3, red lights yourself or send it in for a fix
Oct 25, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
What is the problem when red light is appear?
the other tech is correct but theres also other causes. if 4 red lights are flashing making a full ring your av plug at the back of the xbox is not plugged in. if it has 2 red flashing lights yor unit is overheating. 3 red flashing lights means your cpu is unstuck and is stuffed. 1 red flashing light is a HDD issue
Jun 16, 2009 | Microsoft Xbox 360 Console
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
DISSATISFIDED
check to see if the carriage is moving out of the service station area. If its not..there is a white plastic sensor that is not moving properly. Did you have a paper jam recently?
Durabrand PDV 705 problem
It seems obvious that you have a bad battery. You'll need to find a replacement.
Geno
Mar 04, 2008 | Durabrand PDV-705 Portable DVD Player
Xbox 360 re red flashing lights
depends on how many red lights are flashing...
if you have 3 flashing red lights your machine has a hardware failure which means unfortuanatly your beloved is dead. in which case take it back to the shop and demand a new one. this is a very common problem.
if its only one red light the problem is your av/component cables are not connected correctly....good luck
Feb 07, 2008 | Microsoft Xbox 360 Console
Epson Stylus Photo R220 InkJet Printer Logo
107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
