Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
My bissell proheat x2
It wont push out the water so that i can clean my carpets but it lets the solution go though
  • richard_mudg Oct 14, 2008
    I can apply solution but no water comes through, neither on heavy traffic nor on rinse.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ewty
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell carpet cleaner wont **** water out of carpet.
heatman101
rw245
Apr 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Since the last use of my new ProHeat X2 carpet
Check the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool mode). On the underside of this section is a small (about 1 inch square) red plastic piece with a little door on it. Flip open the door and you will probably find it is clogged. Clean it out and you should have full suction again.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The bissell proheat is leaving too much water on the carpet
Sounds as though the machine needs a good clean before using again. Remove all the dirt, grease and hair from the transparent areas by removing the covers and then reassembling. Also this can be caused by running the cleaner too fast across the carpet.
Aug 26, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
Jun 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water comming onto the cxarpet
remove the water tank and pull up those two red tabs unhook them and push something small thru them they are clogged up that is where your water releases it works I just did it and my bissell works great now!
Feb 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
