Question about Gateway Computers & Internet
GATEWAY 700GR DESKTOP GETTING A THRMAL-EVENT(POSSIBLE OVERHEATING) THEN SHUTS DOWN IS THIS CAUSED FROM POWER SUPSUPPLY THE 1 THAT IS IN THEREIS A 305NEWTON
5 Suggested Answers
  • 57 Answers
SOURCE: I need detailed instructions on what cables go
I found this detailed instide view on Gateway's support website. I must say that this instructional support site is extremely well put together. Hope this helps. Best Regards, -md
http://support.gateway.com/s/PC/R/3726/3726iv.Gatewat 700GRshtml
Posted on Nov 10, 2009
  • 644 Answers
SOURCE: Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Posted on Feb 19, 2010
Testimonial: "That explains a ton, didnt know I need extra software for Gateway. Only one question. Dan o you know wher I can get the software. TY"
SOURCE: possible power supply or ram problem
before you tear into all that hardware stuff please first try this. Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Posted on Mar 05, 2010
Testimonial: "Been helped on several things with this mans guidance. Alays points you in the right direction, and I thank him for his support on this site."
fanaudi
  • 1381 Answers
SOURCE: the PC shuts down randomly.
Hello antmanv1
It's nearly certainly a psu issue . Replace it by a more powerfull one .
A defective fan ( CPU or general ) could also cause malfunction . Check this first .
Download Speccy to have control on temperatures and all functionning devices : http://download.cnet.com/Speccy/3000-2094_4-75181811.html
Best regards .
fanaudi .
Posted on Mar 17, 2011
GM5664 shuting down
You can check temps in your BIOS. That'll tell you if it's an overheating issue.
If temps are normal, suspect a problem PSU or even other hardware. My first guess would be overheating though.
You can check for shorts on the board or bad capacitors. But these are pretty classic symptoms of an electrical or overheating problem. Your temperatures aren't indicating overheating, so there's something funky with the electrical/power system.
The fact that it shuts down with a higher performance mode to me would indicate faulty power.
It sort of seems to me that either you have two bad PSUs (unlikely but entirely possible) or you have a motherboard problem. Replacing a power supply is both cheaper and easier than replacing a motherboard. Now, if you get a third PSU and you're still having the same problems it might be time to look at the motherboard and it's components.
and also Swap the power supply for something like this one:
Newegg.com - SeaSonic S12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
/or/
Newegg.com - CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Apr 18, 2014 | Gateway GM5664 Desktop PC
Computer shuts off at random
It sounds like it's overheating, check your fans make sure all are working, if your fans are all working then your power supply is overheating and should be replaced. If your system is a laptop the battery can overheat also and shut the system down. So you can have different issues dependent on laptop to desktop.
Feb 03, 2012 | Gateway Computers & Internet
My gateway nv5207u turns on laods windows, gets to desktop screen and then shuts off, about a minute every time than its off, then i need to press the power botton again, any clue?
You laptop is overheating. Check whether you are hearing the sound of processor fan working and check the bottom of the laptop where processor fan is located getting heated. If yes, you need to take that to a technician
Mar 24, 2011 | Gateway NV5215u Notebook
Possible power supply or ram problem
Mar 05, 2010 | Gateway 700 X PC Desktop
The PCI serial port doesn't operate cash drawer
Check your windows firewall program. Make sure your firewall is not blocking the cash draw. Your cash draw program is like a internet connection and the firewall program would be blocking it.
Dec 29, 2009 | Gateway 700GR PC Desktop
I have a desk top computer that shuts down when I try to sign on in 1 minute then it starts back up and shuts down again
that can be caused by a few things.
1. bad motherboard: Could be failures on the board, such as a popped capacitor, or a weakened power supply. If your video card is integrated into your board, you would replace them both.
2. bad memory: You could be losing ram integrity, and the computer could be rebooting itself. Try starting in safe mode, and also try starting in "disable reboot on failure" mode to get the error code from the blue screens.
3. corrupted windows: Your OS could be corrupt: a bad sector on the drive or a corrupted registry entry, or even a virus.
4. bad video card: The memory area of the video card could be affected just like the memory of the system board. Also, if your video is integrated onto your board, you will need to replace them both.
5. Thermal event (overheating): The cooling fans on your machine could be failing, causing the cpu to get hot and reboot.
Since you did not share any details about the crash, I cannot be specific about what is happening, but those are the 'usual suspects'
Dec 13, 2009 | Dell Dimension 3100 PC Desktop
Two month old Gateway DX4300-03 randomly shuts down when on the internet.
I have the same pc my power supply went bad after 2 weeks.Pack up the pc and return it ASAP I have nothing but problems with mine.Gateway use to make good pcs, those days are gone,mine was a gift and I had to keep it.
Nov 19, 2009 | Gateway DX4300-03 Desktop PC
I need detailed instructions on what cables go where on my new power supply for my Gatewat 700GR desktop PC
Nov 09, 2009 | Gateway 700GR PC Desktop
My 8:1 media card reader is incompatible with the SDHC memory in my new camera. I need to upgrade the reader or possibly find a firmware upgrade. I do not know the maker of the internal device and I would...
This will do the job: Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0pt 5.4pt 0pt 5.4pt; mso-para-margin:0pt; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Rosewill RCR-IC002 74-in-1 3.5" Internal Card Reader. I think it costs around $15.
Oct 20, 2009 | Gateway 700GR PC Desktop
Need to know the model/number of the motherboard
See this article. Or open the desktop and have a look.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 29, 2009 | Gateway 700GR PC Desktop
Computers & Internet Logo
87 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
