Question about Sub-Zero 695/S Side by Side Refrigerator
Icemaker works but dispenser not working - Sub-Zero 695/S Side by Side Refrigerator
  • 7 more comments
  • kristinJ Sep 09, 2008
    Icemaker makes ice, but will not dispense water or ice. Lights on outside also quit working and water leaks out of water dispenser.
  • stop work Sep 21, 2008
    Wow, we are having the same problem - the ice "maker" is working just fine. The only way to get the ice out is to open the door and take it out of the collection bin. While I admit this is no more than an inconvience but it demonstrates the lack of material workmanship and quality of this product.
    Makes ice = yes
    dispense water = yes
    light comes on = yes
    dispense ice = NO
    Is the lock button activated = NO (obviously)
    I would appreciate any information on how to fix this problem.
  • Anonymous Oct 20, 2008
    ice dispenser does not work
  • dgregory Oct 24, 2008
    Lots of ice, water works OK. When switch is activated the flapper opens and solenoid activates rod, but dispenser motor does not run and no ice is dispensed.
  • Anonymous Oct 25, 2008
    ice
  • aprilddawson Nov 15, 2008
    My light is on (no flashing) but will not make ice. water dispenser works.
  • sdcooper61 Nov 21, 2008
    I have a similar problem: icemaker working, but not dispensing, but the water dispenser is working intermittently. When dispenser paddle is depressed, the "O" light flashes once on the freezer setting.
  • Brent1442 Nov 25, 2008
    Ice maker works, water dispenser works. When I push the ice padel down, the flapper door opens slightly but not enough to activate to dispenser. I can make it work if I pull the flapper up and depress the padel
  • goobergrafto Nov 30, 2008
    ice maker works, water dispenser works, but ice dispenser does not work
I kind of have the same problem, this only works temporarily but, take out your ice holder, take out all the ice and place it it a bag, Once you have done that check if everything is in place, if something is not, unscrew the cover, and put it back in place. put everything back and try it out again. This should work for about a week or so.
Posted on Dec 28, 2008
I'm not sure what model Kenmore (Whirlpool) I have but I just fixed the problem. Start by pulling the power plug. Next I removed the bottom water tray. This exposed 2 screws, remove them. Then you can lift the front cover up. I saw the plastic pegs that hold the dispenser switch had broken off. At this point you can order a replacement piece with new pegs, or carefully drill 2 holes where the pegs were. I then found some long #4 screws which I used to replace the pegs. Washer on the screw, screw through the hole from the outside, spacer, switch and nuts. Didn't have enough room for lockwashers, so I painted the screwheads and nuts with fingernail polish to lock them.
Posted on Nov 22, 2008
Same problem with me and same fridge
Posted on Nov 01, 2008
Seems like everyone has the same problem, have to take a screw driver and be careful taking the front cover off, it is possible the micro switch could be bad or not making contact somehow. that is my guess. good luck. you can call v and v appliance parts ask for tom 330-743-7300 give model # and he can guide you over the phone and actually give you some good advice on working on it.
Posted on Oct 21, 2008
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
Automatic icemaker stopped working yesterday. No problems before that. Arm is down, no problem with water line, (water still works in dispenser) temp is fine.
there are two solenoids that control water input. One foe the dispenser and one for the icemaker.Its called a double valve
and you have to replace both. even tho the dispenser is working.
Check ice tray for water if it has none pour it full and wait to see if it ejects after it freezes if it does then you probably need th double valve replaced if it don't then probably icemaker replacement
Aug 24, 2010 | Maytag Refrigerators
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
285 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
