Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2003 F.I. Softail
When cold runs rough, and no reponse on throttle. Hot, runs perfect.
  • 116 Answers
Tempature sensor most likely but mapp sensor poss also $25 $30 apeice change both
Posted on Dec 30, 2009
  • 42 Answers
Thats how they run cold, you have to let it warm up a little. Harley EFI is not like a car. They probably need 5 miles of normal warm up before putting them through the paces.
Posted on Aug 10, 2009
    Sergeant:
  • Harley Davidson Expert
  • 284 Answers
Sounds like a mapping issue with whatever f.i. add on you have. could also be the pintle sticking on the throttle body. take the air cleaner off, look at the inside of the throttle body. at the top there will be a little hole. that's where the pintle is. it retracts and expands for cold starting and hot idle as well. if you turn the bike on and off it should cycle. ( extend and retract ) if it doesn't then the pintle needs to be replaced.
Posted on Jun 11, 2009
84 mustang 5.0 auto-Idle problems. runs Ok when cold , runs rough and stalls when warm. 1st year throttle body injection. was told the IAC valve needs cleaned. can`t find on car
the iac sensor is along the side of throttle body , did you give the throttle plate area a good cleaning out this is where the air path is for the IAC sensor , a lot of idle problems have been fixed with a can of throttle body cleaner and few good squirts of the stuff down the hole
Sep 10, 2015 | Cars & Trucks
'87 Yamaha ProV 50: Will cold start and idle well. After a full throttle 1-2 min run will begin & continue running very rough near idle. Will die without addtl throttle imput.
Hi Roderick:
I'm not familiar with your engine configuration, but on some of the older bikes, vibration eventually can cause a wire to break in the coil. When the engine is cold, the wires make contact and it runs, but as soon as it gets hot, the connection is broken or compromised and the spark quits or drives you crazy.
Since your bike runs when cold and quits when hot, I'd be looking for electrical rather than fuel problems.
Hope this helps.
Sep 09, 2015 | Yamaha Motorcycles
Rough idle
Sounds like a automatic choke sticking....Take the air duct loose from carb..While accelerating engine spray bottle throttle spray in.....as the car tries to die...stop spraying...Repeat 3 or 4 times.....It will clean your injectors. Runs alot better...Remember....bottle throttle spray...not carborator spray
Aug 12, 2013 | 2003 Chrysler PT Cruiser
EVAP Hose on my 2003 Harley softail is broken
Hi Scottynukem, take a ride or drive over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary and offer professional advice and assistance concerning your issue. Have a nice day.
Apr 02, 2013 | 2003 Harley Davidson FXST Softail Standard
I own a 03 chevy 5.3 liter z71 runs good but loses all throttle response. check engine light comes on and says loss of engine power. i pull over put it in park it has a rough idle. i can push on brake and...
Sounds like fuel starvation. 1) change fuel filter. 2) change fuel pump. GM pumps don't hold up to water in the tank (methanol fuel) very well. Its a 2003 so its probably time. Never replace as many parts as you have, without first performing an OBDII scan of the stored fault history, to avoid buying parts you don't need
Jun 04, 2017 | 1996 Chevrolet Cavalier
2003 F250 Super Duty diesel 6.0 needs multiple tries to start.
It is a Ford. Replace the fuel pump and check the fuel lines for leaks including any filters.
Nov 01, 2017 | 2003 Ford F250 Super Duty Crew Cab
Saab 95 2002 3.0l v6 turbo. when warm, starts to
Have you had your mass air meter checked or replaced? This is the unit attached to the air intake hose behind your air filter. It senses the air temperature, speed, density, etc... and adjusts the fuel/air ratio to keep the vehicle running at "peak" performance. Also, check your TPS (throttle positioning sensor) it can also cause the problem you speak of. The TPS adjusts your engine speed/idle etc. and also compensates for hot/cold changes etc. This is roughly a $35.00 part and in most cases usually an easy fix.
Nov 01, 2009 | 2003 Saab 9-3
I have a ford f250 superduty 2003 diesel. It started to run rough when ideling. also slow reponse when you take off. I have just changed the oil, air filter, both fuel filters, and drained fuel for...
Sounds like an ECU issue.  check your fuses, see if you can get an error code from a scanner, they have one at most checker auto stores that you can use for free.  Could be a Intake Air Temp sensor or a Throttle Position Sensor.  Thats what I would start with.  Good luck.
Jan 23, 2009 | 2003 Ford F250 Super Duty Crew Cab
Idles rough when cold
the throttle body is icing. there are engine coolent lines running to the intake plentum. flush youre cooling system and see if that fixes it
Dec 30, 2008 | 1991 Ford F150
Lands Phones Logo
151 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
