Question about Apple ILIVE IB-R2807DP PORTABLE MUSIC SYSTEM WITH IPOD DOCK (047323128073) Docking Station
Headphones When I plug in my headphones the volume is still on so everyone can still hear what I am listening to? I listen at work so this is causing quite a problem. Is there any way to just listen to my headphones?
  • Apple Master
  • 2,794 Answers
Either the resistor that shuts power off to your speakers when it is plugged in is either missing, shorted, or blown. If you know where to get the unit fixed, that should take care of the problem.
Posted on Sep 09, 2008
Trying to get new headphones to cancel speakers on tv
What kind of headphones and TV are you trying to make work as an combined pair? It sounds to me as though you have your head phones plugged into the speaker location on the TV which could be a small hole that shows a pic of speakers. Look on the TV for an 'mic' or 'pic of headphones' holes. If there is an plug in hole with either it states mic or shows a pic of headphones plug the headphones into that hole instead of where you have them plugged into now.
Another suggestion is to use MDI cords in which you may already be using aka white, red, yellow colored plugs. If those plugs are assembled in the slots incorrect that also could be the reason as to why the headphones turn down when you turn the volume to the TV down; which also would influence the TV volume its self to also disengage to go either louder or quieter. MDI cords should be plugged in the following pattern to be categorized as the following with each color following the next color; yellow, white, red. Now if you are using MDI cords presently do you have them plugged in front or back of the TV?
If the TV has hole ports in both front and back for MDI cords then reverse your plug ins. Example: If you have them plugged in the front instead switch all three to the back of the TV or vise versa.
Also another thing; since you are wanting to use headphones for your TV speakers instead of the TV speakers themselves usually plugging headphones in are controlled by TV volume buttons; however I am assuming that you are trying to state that when you plug headphones into the TV you still hear the volume in your ears and anyone in the TV room is also still hearing the TV even though headphones are plugged in, am I right?
With you wanting to cancel the speakers on the TV out only attempted to use TV volume for speakers and without it working means you have the MDI cord plugged into the audio which would cause the TV to power the volume for the headphones anyways. May I ask this; since I am a bit confused, alright are you wishing for the headphones to be able to be loud enough so the TV only powers them for volume when you use the TV?
I know that headphones being plugged into an TV should only keep their volume within the ear buds. Therefore I have never heard of headphones being able to be loud enough to power out room sound. Instead they power internal volume which would be within your ears. Headphones were meant to keep noise and volume from surrounding a room to block room noise out and to keep the sound for your/ an own persons only listening capability. So because of this I am confused as to how ear phones would have the ability to sound the room with audio.
I can understand that if what you are trying to say is that the speakers on the TV still output volume even with head phones plugged in which would be an issue, since head phones are to capture the volume and noise from the unit in which plays aloud- to actually silence it instead- for the individual whom requires or presumes to have themselves to be the only listener.
Jan 02, 2014 | JVC 900MHz Wireless Stereo Headphones with...
Panasonic RP HT711 headphones.
There could be a mismatch between the impedance of the headphones and the devices you plug into. In short, the Panasonic headphones may not be intended for the type of listening you are attempting
May 24, 2013 | Audio Players & Recorders
Help with panasonic wireless headphones
When you plug your headphones in mechanically, you cut off the speakers. No way this is going to work.
Jul 10, 2017 | Panasonic Audio Players & Recorders
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
My laptops speakers stopped working
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
Jun 24, 2009 | HP Compaq Presario 2500LA Notebook
Headset icon on nokia 6280
Have Her Make A Call Then Plug The Headphones In And Out 3 or 4 Then See If The Problem Persists.
Jan 14, 2009 | Toshiba Satellite 1400-S151 Notebook
No sound driver
Turn the power off. Wait about 10 seconds,then power up again get close to the reciever and listen for a click-not from the speakers ,fromthe recievers itself.If you hear a click,you can assume that the power supply is ok for that cercuit.This does'nt eliminate the power supply,but it will do for now.Put the speakers close to the reciever,what you will do now is to power up the reciever while listening to the speakers with the volume off.In about 3-5 seconds you should a hear a slight click from the speakers. Try this with both speakers if you don't plug in a pair of headphones to the headphone jack and play the source . If you still no sound with headphones you at least now know that the output transistors are not the problem or the only problem.The power amp., section are defected also.Message whatever happens.
Jun 17, 2008 | Audio Players & Recorders
Can these be hooked up so you can hear the tv external speakers as well?
I have the headset running through an amplifier so my wife can listen at her volume level and I can adjust the headset volume for myself. The volume dial on the amp is set to zero; but the audio output jacks still provide plenty of volume to the headset. You can get a reasonable amplified for $100 or less
May 27, 2008 | Sony MDR-RF970RK Headphones
Apple ILIVE IB-R2807DP PORTABLE MUSIC SYSTEM WITH IPOD DOCK (047323128073) Docking Station Logo
75 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
