Question about Dell Dimension 1100 PC Desktop
Sound Is Skipping
I have reinstalled all my codec's, my soundcard (SoundMAX), my WMP and every song even on the internet sound is skipping like a scratched cd! I have tried iTunes, VLC player and it still skips! Not sure what else to do! Can someone help?
  • 10 more comments
  • mj2009 Sep 08, 2008
    I had WMP open, Internet Explorer, and Outlook Express! However I restarted my PC and only tried WMP and the problem is still there! I have already shut down most programs that were running in the background!
    This problem only started after I packed my computer, moved across town and hooked up my computer again! It was there and since then I had a Microsoft update to install service pack 3 which I have done!
  • mj2009 Sep 09, 2008
    Okay I tried that but its still doing the same thing! Even when my computer starts up the welcome sound is choppy! Could it be the soundcard itself? ...it looks like the soundcard is also made onto the motherboard is that true in Dell computers or am I just not looking in the right place? ..
    Thank you so much for trying to help I also did that twice and that did not help either! Its a real puzzler and driving me nuts!!
    The soundcard is a SoundMAX Integrated Digital Audio ....Driver Version 5.12.1.7000 .....Driver Date 3/22/2005
    ..... I uninstalled it from the device manager and reinstalled it with the discs that came with the computer as well as the one online using my service tag!
    Oh sorry for the confusion but It is an onboard sound!
    Okay, I have Windows Xp Service Pack 3... I already have Ad Aware and CCleaner so I will do all the steps you have suggested as well as defraging and disk cleanup... It could take awhile but right now I have 37 processes running and the CPU is ranging from 8% - 25% as the highest I have seen... I will get back to you on the number of items found!
    Some more info not sure if its means anything but
    Processor
    Manufacturer
    Intel(R) Celeron(R) CPU 2.53GHz
    Clock Speed
    2.6GHz
    Okay I did all that! I ended up with 161 items in ccleaner and 34 items in adaware and I did a defrag and disc cleanup and the problem still exist! .. it is very frustrating and I am not sure what else to do that I have not done!
    Hey thanks Robert, take care of your family first though! I am in no hurry! Help when you are able too!! ... once again thanks!
  • mj2009 Sep 11, 2008
    I have DJBCP Codec Pack & VP6 VFW Codec thats all I have installed! I have WMP10
    After looking through some properties on my device manager I found these other codec's Don't know if it means anything!
    Okay I have solved my problem! I did a system restore in safe mode to the last known date that my sound worked and that was a date before I moved! It was a success, my sound is working perfect! I am thinking that maybe one of the updates from Microsoft conflicted with the dell operating system! I could be wrong but the main thing is my sound is now perfect and I am very happy!
    Robert (bunnydawg) you were a great help and your tips were very helpful! Thank you so much!!
    mj2009
  • Roberta Smith
    Roberta Smith May 11, 2010
    how many programs do you have open at the same time ?
    Robert
    Brigadier General:
  • 5,158 Answers
I'm still thinking memory issues.... quick fix would be to unplug the memory module and then plug it in again.... it may have come unseated..... please make sure the power is off before you do that.
Robert
Posted on Sep 08, 2008
  • 6 more comments
  • Roberta Smith
    Roberta Smith Sep 09, 2008
    I've had choppy sound with laptops before but not desktops... be that as it may go to www.dell.com click on support and chose the model of your computer... download the sound driver and reinstall it.
    Robert
  • Roberta Smith
    ok i am embarrassed now.... didn't notice the reference to an add on sound card. what is the model number of the sound card. you may have to remove it to find the number unless you still have the box. it may also show up in device manager but i suspect it is the wrong driver.
    I hate when i miss the obvious.
    Robert
  • Roberta Smith
    but is that onboard sound or an add on pci card ?
    Robert
  • Roberta Smith
    what operating system are you using ?
    vista by chance ?
    Guess we need to start with basics to troubleshoot this so get out the coffee now. first download these programs. adaware, spybot s&d and ccleaner. google to find them.
    Second go to start-my computer click on that... you will see your hard drive icon.... right click on that then click on disk cleanup..... after it has found all the files it can safely remove make sure there are check marks in all the boxes
    click ok and let it do it's thing.
    Next you need to defrag your computer....
    after that install each of the programs you have downloaded
    run adaware first.... make sure you update it before you run the scan.... remove all that it finds
    next run spybot... update first then run a scan... remove all it finds.
    next run ccleaner
    also i would like you to hit control alt delete at the same time.. no it won't reboot your computer unless you are running win 98.
    task manager will start.... i'm interested in cpu usage and memory usage.... both are at the bottom of the window.
    let me know what they are as well as the number of items adaware and spybot find
    Robert
  • Roberta Smith
    on the second step.... start... my computer .... right click on the hard drive icon and select properties
    then disk cleanup
  • Roberta Smith
    Thanks for that information
    when those things are done we will attempt further troubleshooting.... i realize how frustrating it is but we will arrive at a solution.
    Robert
  • Roberta Smith
    I have some family issues to take care of. i will try to devote as much time tonite to the issue and see if we can't work out a solution ... i understand your frustration
    Robert
  • Roberta Smith
    Roberta Smith Sep 11, 2008
    Ok i'm back... i've been thinking more about the issue which codec pack did you install and do you have more then one pack installed on your machine ?
    Robert
Sound max HP Compaq dc7100
Really?
You're one of the X-men and you can't solve this problem?
Sheesh! Where have the world of superheros gone?
Why I remember a time Ol' Green Lantern, and me..............
...........What?.................Oh...................
OH, I'M JUST KIDDIN'!
You didn't state the Operating System you are using, so I am going to use Windows XP Home Edition for an example,
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=410114&lang=en&cc=us&prodTypeId=12454&prodSeriesId=410112&taskId=135
Driver - Audio
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=410112&prodNameId=410114&swEnvOID=1098&swLang=13&mode=2&taskId=135&swItem=vc-86494-1
Now is that for a Soundmax? Dunno.
Do know you can look the model number up on the soundcard, if it is a SoundMax soundcard, go to SoundMax support, and download the drivers.
http://www.soundmax.com.tw/productlist.asp?action=hot
I can tell you how to step by step download AND install, the drivers on the HP Support page; or the drivers from the SoundMax page.
Post back in a Comment.
Regards,
joecoolvette
Jan 24, 2013 | Computers & Internet
I bought a used GX520 and the volume does not work. There is no volume icon on the lower right corner. Under sounds and audio devices it says ''no audio device'', and I can't change anything. I own another...
sounds like ( no pun intended) your missing the audio drivers or controllers--right-click on MY COMPUTER then PROPERTIES then HARDWARE then DEVICE MANAGER and check if there are any yellow or red "X"s next to anything (you sound driver) right click and select update driver (you need to be connected to the internet)
Sep 17, 2009 | Dell GX520 PC Desktop
No soundmax audio present.
I need to ask. Do you have two speakers showing? One fat red one and one gray one as you usually see on computers everywhere?
Try this either way.
Go to Start, All Programs, Accessories, Entertainment, Volume Control and make sure you don't have a check mark in your Master Volume control found on the far left.
Are you using a Desktop or laptop?
Jun 26, 2009 | Lenovo ThinkCentre® A51 PC Desktop
WMP/Spotify doesn't work properly
if you are using the PC's motherboard sound I would upgrade to a soundcard. they are relatively inexpensive and easy to install. www.pricewatch.com
Apr 12, 2009 | Computers & Internet
Playback on audio cd's sounds bad. Sounds scratchy.
I would always install the driver first , especially if they have an updated version since your last install. also might check if there is a direct connect line attches from the back of the cd rom to the soundcard or motherboard. sound newer motherboards handle sound better without these.
Apr 04, 2009 | HP Pavilion 521n PC Desktop
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Sound Is Skipping
Have you installed anything else on your pc
is this xp
Jan 16, 2009 | Dell Dimension 8400 PC Desktop
Need Audio and Video driver for Medion md-1768
Not sure on the Video but uninstall the soundmax and use realtek AC-97 driver available at
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Realtek-AC97-Audio-Codec-Driver-A397.shtml
Oct 17, 2008 | Medion MD-1768 PC Desktop
Sound
i need soundmax for my orange pc
Mar 27, 2008 | HP Compaq d220M (829160054797) PC Desktop
Dell optiplex gx270 soiund device
MY OPTILEX GX270 AUDIO DRIVER NOT INSTALL WINDOWS XP.
I FORGET MY SOUND DRIVER NAME.
KINDLY SOLVE THIS PROBLEM.
Feb 01, 2008 | Dell OptiPlex GX270 PC Desktop
Dell Dimension 1100 PC Desktop Logo
360 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
