Question about Sony Ericsson W850i Cellular Phone
Just got a new phone..need to set up mms profile to send picture msg to the United states
Hi..i just bought a new sony ericcson phone..ive been trying to send a picture message to someone in the United States...do i have to set up a profile for server or something like that for it to work...ive been trying to figure it out for days now...phone is with Rodgers...they cannot figure it out..ive tried using the country code for the U>S>...etc...my phone says it has been sent over and over again...but the reciepient has not received the photo....Help pls....Karen
    Brigadier General:
  • 7,752 Answers
Sorry but you will need to check their website for the MMS settings or take it into they service center for assistance.
Posted on Oct 21, 2008
Problem sending any of my pictures in form of sending them mms. i get a shutdown msg saying, process com.android. mms has stopped. how do I fix this problem? I have a Android ZTE Warp
Hi Elizabeth, this problem usually occurs to a corrupted database. The easiest way may be to backup and reset your phone, you can also try the below which may work for some phones.
Go into settings >>> language and keyboard >>>> select locale >>> english United States /or change the locale.
May 26, 2014 | Cell Phones
How to activate & send mms in samsung s8000 mobile
you need to configure the mms settings from your internet menu... but you need the right configuration from your network provider to the settings..
to give you an idea, here's how you may do it.. from your phone, press menu select internet select browser profiles to lead you to internet profile settings.. from your settings, press create.  then create the mms profile your network preferred.  once created, press save and exit the settings for internet profiles..
to make the mms profiles be the default settings for your mms, do thes steps... from your phone, press menu select settings select phone applications select messages select multimedia from multimedia menu, select profiles assign the mms profiles you created for your multimedia. press save and exit the setup...
now to check if it's working, try sending a multimedia message to your own number to check if your phone can send and receive mms. once you successfully send it and received it, it means that your phone mms is already set and working...
take care..
Mar 30, 2010 | Samsung Jet S8000 Cell Phone
Tmobile mms settings for lg kf900 prada 2
i got this from here
From the home screen go to Menu, Settings, Connectivity, Network, Network Profile, Data Connections, New Profile. Fill in the spaces as follows.
Bearer: GPRS
APN: wap.voicestream.com
User ID: Leave Blank
Password: Leave Blank
Primary Server: 216.155.165.050
Secondary Server: Blank or all zeroes
Now from the home screen go to Menu, Browser, Settings, Network Profile, New Profile. Fill in the spaces as follows.
Homepage: http://wap.myvoicestream.com
Proxy: On
IP Address: 216.155.165.050
Port: 8080
Access Point: Select the Tzones profile you've created in the last step.
Now click Save. It should return you to the previous screen with the heading Network Profile. Select options using the proper softkey and select activate. There should now be a checkmark next to Tzones.
To make sure your settings are correct so far, use the browser's homepage to test that the settings have taken effect. You should see T-Zones homepage as you would on any standard T-Mobile phone. If it does not work, double check your settings and shutdown and restart your phone and try your browser again.
For some reason I could not get our phones to work without setting up the browser as well, which is why I've included this step. Now on to the final step.
From the home page select, Menu, Messaging, Settings, Multimedia Message, Network Profile, Add. Enter the following information.
Profile Name: Picture Messaging
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
Internet Mode: WAP
Proxy IP: 216.155.165.050
Proxy Port: 8080
Connection: Select Tzones
Click save and return to the Network Profile in the same menu. Select Picture Messaging to activate it. There should now be a checkmark next to Picture Messaging. Now send a test text. If it does not go through, shutdown and restart your phone and try again. Once operational, you will have a phone that can use all major functions on the T-Mobile network including picture messaging, web browsing, and should also allow downloading of ringtones.
Dec 02, 2009 | Cell Phones
Unlocked LG Vu won't send or receive picture messages
go to messaging. go to settings. multimedia message. message center. options new.
name= T-Mobile MMS
MMSC url=http://mms.msg.eng.t-mobile.com.mms/wapenc
MMSC proxy=216.115.174.050
MMSC port=8080
Connection mode= TCP without proxy
Network profile= T-Mobile WAP
Autorization=PAP
leave username and password blank.
Apr 23, 2009 | LG Vu CU920 Cellular Phone
MMS profile
Hello Sir,
For using MMS or GPRS facility you will need a setup for your desir cell phone. To get this setup using MMS facility please call your service provider help center and request then to open your MMS facility if it is open already then told then send new setting for you new mobile phone. You will give then your phone brand (e,g Sony Ericsson) and number ( e,g K800i). You will shortly recive a message from your cell phone service provider follow the instruction and install new setup for MMS.
If you need more help regard this problem let me clear you more.
Have a nice time.
Regards
nidostyle
Nov 16, 2008 | Sony Ericsson K800i Cellular Phone
I cannot recieve MMS..
Goto the samsung mobile below
and click on MMS settings
follow the instructions
http://uk.samsungmobile.com/supports/supportMain.do?&menuIdTop=00000000000003
That will get the settings for picture messaging sent directly to your phone
Apr 29, 2008 | Samsung SGH-U600
Picture received in a small size.
try resetting the settings back to it's default or check your mms settings
Dec 29, 2007 | Sony Ericsson Z610i Cellular Phone
K8oo mms profile settings
You need to call your service provider and ask them to send you the MMS settings.
They will give you a PIN number and send the settings via a txt msg.
When you receive the txt. select SAVE or INSTALL.
Input the PIN when prompted.
MMS does not always work between networks.
Dec 27, 2007 | Sony Ericsson K800i Cellular Phone
A blue mark is perminant on my phone screen and i cant get access to the internet from new zealand or send mms
hi see what u can do is for sms there is a particular no. fior that which u can get it from the service provider,and as far as the internet is concern u can get ur software reloaded from any of the vendor nearby u. they will change the software neccessary for ur phone which will unblock the profiles after that u can try to acces it.
Oct 16, 2007 | Sony Ericsson Z610i Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
