Question about Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001)
Can I use a Powerline product on a European 220 volt electrical system?
    Scholar:
  • 130 Answers
No. Currently we are only offering Powerline products for the North American market, with support for standard 120 Volt AC, 60 Hz electrical outlets. Simply plugging a 120 > 220 volt adapter will not work, as the transformer will block the broadband signal, not to mention that the increased voltage that is likely to leak through a standard adapter could destroy the product.
Posted on Feb 19, 2006
I wish to take the Ellure Plus machine to India where the power supply is 240 volt. What shall I do? What is the power requirement in Watts for this machine. Your feedback is highly appreciated.
You will need to check with the instruction manual of your machine what the specifications are.
Today the 120 volt mains, I am told, is almost a thing of the past and 220 volt is much more common. The UK mains electricity used to be 250 volts but it has been lowered to 240 and eventually it will be lowered to 230 volts to bring us closer to the European specification.
Because most electrical equipment is imported and we are a minority market, electrical manafacturers didn't want to produce specail goods just for us and so for 20 years or so most of our electrical goods are suitable for use in a range of mains voltages from 220 to 240. Sometimes they are marked as such and sometimes marked as 230 volts but we are told 240 won't damage them and they will still work efficiently at 220. It is only very old electrical equipment made for 250 volts that seems slightly less efficient.
Some equipment is made for universal use and will accept 120 volt mains as well as the 220 to 240 range. In this case there is usually a provision to select a different voltage by means of a switch or by changing some simple internal wiring connections. Details of how to do this is invariably printed in the manual.
Equipment produced for 110/120 volts only would become dangerous and be soon destroyed if plugged directly into a 240 volt mains but a transformer can easily be obtained to allow 120 volt equipment to be used on 220/240 volt mains. A great many professional tools are still produced to use 120 volt electricity for reasons of safety and so auto-transformers of all sizes are commonly available and not too expensive.
I have a fairly limited experience of sewing machines but I think a domestic machine has only a very small appetite for power and a supply suitable for a reading lamp will be more than adequate. The exact wattage of your machine will be found in the instruction manual.
Apr 10, 2016 | Sewing Machines
Solis 365 royal hair vac I was wondering if it was possible to use this product in australia due to the voltage difference and if there is a product made to suit australian voltage or if an adaptor...
There are products called Step Up transformers/Step Down (Voltage Converters) that can be used. We use these For our 220VAC Australian manufactured lasers when we need to run them in a Dr.'s office that only has US 110VAC.
Info from a website:
Electrical voltage in USA is 110 voltwhereas; the voltage in most of the foreign countries is 220V to 240 volt. A voltage converter / transformer, also known as power converter are usedto convert electricity coming out of the wall to match the voltage of yourdevice. These Voltage transformers or converters can be used safely withRefrigerators, Microwaves, Juicers, Blenders, Coffee makers, Power Tools,Stereo Systems, TV's, Video Games, DVDs, Hair dryers, Chargers, computersand other electronics when travelling abroad..
Remember to leave at least a 100-percent margin for power surges/spikewhen buying a transformer. Some items, such as Televisions, computermonitors spike when you turn them on. For these products you need to buy avoltage converter transformer that is at least 3 times the items capacity.Power tools, laser printers and heating appliances like coffee makers,toasters, microwaves, Halogen, Fluorescent bulbs you must leave a marginof 3-4 times.
Voltage transformers are made to convert single phase 110 or 220 volt.American 220 Volt consists of 2 phase of 110 Volt and European 220 Voltconsists of 1 phase of 220 volt.
Volts x Amps = Watts (i.e. 110V x 0.5 AMPS = 55W). Please make sure not torun any appliance with higher wattage then voltage transformer's wattage.This might damage both: your appliance and the transformer!
I hope this helps.
PHmaddnes Transformer Purchase Guide
May 06, 2014 | Cell Phones
What lcd tv will work in Ghana in Africa?
You can buy a any brand LCD TVmade for England , Germany or India.
The working voltage should be 220/240/volt 50Hz and the color system should be PAL/B.
Mar 08, 2011 | Televison & Video
How do i make it PAL 60 rather then PAL 50?
PAL 50 is the european broadcast standard, as I am sure you are aware.
There is no "PAL 60" - If you are trying to set up for use in the United States, the correct setting is NTSC.
Not all sets will allow you to change from one broadcast format to the other. You must consult your manual to see if it is capable to set it up for NTSC. If so, follow the instructions and the set up menu.
One very important item.... US households are wired to run off of 110 to120 volt, 60 hz AC. The European standard is 220 volt, 50 hz AC. You must check your manual to see how to set the correct input voltage.... some sets can configure themselves automatically, and some have a small "slider" switch to change from 220 to 115 (or it may say 110 or 120, but they all serve the same purpose). Make sure you do this BEFORE powering up a European set in the US!
Feb 13, 2011 | Televison & Video
Hello, I was wondering if I could wire a 220 volt european miele dishwasher to a 220 US power.
Hello
You need to be sure of the amps,most major appliances in the U.S. run on different amperage.
Check the electrical requirements closely.You may need to change the outlet or the plug for the dishwasher.
Nov 23, 2010 | Miele G848I Dishwasher
My download speed has been reduced from 20 Mbits to 2 Mbits after having plugged in a set of XE102. Why? Can I do something ? Regards Mogens Villy Møller Copenhagen Denmark
The top speed between the devices is 14 Mb/s, so they will never attain the 20Mb/s speed you had with you router / modem.
Netgear offers this FAQ for Powerline devices:
Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
  • Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or uninterruptable power supplies.
  • Passwords. Powerline products have both a network password, and a device password. A particular device's password, which is not changable, is printed on the Powerline product label. Once you have collected all your Powerline device passwords, use the encryption dialog box, as described on pages 9 and 12 of the XE102 User's Guide, to change the network password. (Without password protection, it is possible, although unlikely, for someone very nearby to access your network.)
  • If you changed the default network password, make sure that all the Powerline products use the same network password.
  • If you've moved a Powerline unit, or disconnected the cables, your other network devices may need about 5 minutes to refresh their information about the Powerline's current status.
  • If you have earlier Powerline products, switch to the encryption used by later products. (Early versions of XA601 and XE602 are known to have compatibility problems with newer models.)
  • To test whether a house's electrical wiring is contributing to Powerline problems, plug units in the same room. Examples of potential problems are:
    • Old fuse boxes.
    • Old wiring that does not meet modern wiring building codes.
  • Swap devices to isolate the problem to a particular Powerline unit.
  • Reset the Powerline adapters to the default settings using the utility.
  • Use all the same Powerline models for best connectivity. Also, software for one model may not work for another model. In particular, remote and advanced features may not work between Powerline manufacturers.
  • Powerline is not directed at businesses, however it may work in a business environment, anyhow. See Assessing Powerline for Business Environments. In some cases noise can be limited by placing line conditioners or surge protectors between the source of the noise, and the Powerline units. (Not between the units.) Consult a professional electrician to evaluate your electricity's noise and to suggest remedies.
Sep 29, 2009 | NetGear XE102 Powerline Ethernet Adapter...
3 wires black white ground from box from oven red black white ground what goes where
the appliance is 220 volt and the box you are describing is 110 volt. You cannot connect to this box. You need a new 220 volt circuit ran from your main panel box to the appliance with a 220 volt 3 prong outlet box like an electric dryer uses or make the connections in a box without using the plug system
Aug 17, 2009 | Frigidaire (FEB30S7D) Oven
Europran wii
Wii consoles are region-specific and different regions also use different television standards.
You have potentially three problems:
  1. Wii consoles are region-specific. Games for US/Canada won't work in a European Wii
  2. European Wii consoles output PAL video signals. US/Canada/Japan TVs except NTSC video signals.
  3. European Wii consoles likely require 220-volt power. US/Canada/Japan is 100-120-volt power.
So now your solutions for each:
  1. You need to get games from France (or at least Europe)
    You can also look into a device called the Freeloader, but I'm not sure if it works with Wii games yet (the original allowed Gamecube consoles to play games from different regions)
  2. You'll need a multi-standard TV, or a television standards converter. Tourist-y camera shops often sell converter boxes. You need to convert from a PAL video signal to an NTSC video signal in order to connect it to your TV.
  3. Check the power adapter of the Wii. If it lists "110-240 volts" or "100-240 volts" (at least a voltage number in the 100-something range) on it, then the power supply will work and you just need an international plug adapter. You can get these from most travel stores and electronics stores.
    If the power adapter does not list a voltage in the 100-something range on it, then you will need a step-up transformer - that will convert power from 120-volt to 220-volt or 240-volt. The transformer may or may not have the right type of power receptacle, so you may also need a plug adapter. Check your local electronics store for this. Tell them you have a device from Europe and want to run it on your local electrical power. They should know what you need. If you have a choice, get one that is designed for computer or laptop use, as the cheaper ones provide "dirty" power which is fine for hair dryers and such, but bad for electronics.
Hope that helps...
Apr 02, 2008 | Nintendo Wii Console
What amp is the plug?
This is a 220 unit and it must be plugged into a proper 220 volt plugin.
Jun 03, 2007 | Comfort-Aire RAD-183 Air Conditioner
Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Logo
220 people viewed this question
Top Efficient Networks Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Tom Chichester
k24674
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
