Question about Gateway SL9550-30165318 Notebook
Solo 9559 can not pass the initial screen
When I power up my Solo 9550 laptop, I get the Gateway Screen with the Press F2 for Set Up. I do this and everything seems to be identified correctly (I have also unplugged all peripherals in case one of them is causing problems and same thing applies). However, after it identifies componants and memory checks out ok, it says Entering Set Up and just sits there. Any ideas on what might be wrong? I have tried Reset button numerous times and have installed a new CMOS battery (just hoping) but to no avail
  • 4 more comments
  • CarrieL Sep 08, 2008
    I am using XPP. However - getting into Windows is not my first concern. I could always access the BIOS before I ever installed any operating system. Was wondering if the problem may be the BIOS chip itself?
    Oh, I was SO hopeful! I had tried this but not that long. Sorry - but same result. Thank you so much for the suggestions though.
    Maybe more details would help?
    When powering up, get Gateway screen with Press F2 for setup.
    Do that and identifies:
    PhoenixBios 4.0 Release 6.0
    (then copyright etc.)
    Bios version 29.05.04
    Gateway Solo 9550
    System ID - 000000000 (is this normal?)
    Then identifies
    CPU = Intel(R) Mobile Pentium(R) III Processor-M 1066 MHz
    Memory (all passed)
    System BIOS shadowed
    Video BIOS shadowed
    UMB upper limit segment address: E439 (don't know what this is)
    Fixed Disk (correct)
    ATAPI CD/DVD (correct)
    Mouse initialized
    Entering Setup . . .
    Then just SITS there!
  • CarrieL Sep 09, 2008
    Oops - not familiar on how to leave a comment AND a rating....
    The screen did not go blank. After listing statistics, it said "entering Set Up ..." and just sat there - no cursor.
    However - after leaving the computer turned off but plugged in (Had to eat) I tried again - hit F2 and the Bios screen came up. Changed date and time but left everything else alone. F10 to exit saving changes. It went back to the Gateway Screen. F2 again worked and time/date were correct - however it just goes back to "Press F2 to Set up". This time tried Disable on Quick Boot and Quiet Boot so I could maybe see more of what was going on. It ran through tests and LO and BEHOLD! Windows started! Thank you for your help - and HOPEFULLY I won't be back!
  • Anonymous Sep 18, 2008
    Hi ya doing, . I have a problem: The laptop will not get past the POST.
    I stops at "mouse initialized" with the "ESC" prompt at the bottom. So...the laptop doesn't freeze, because I can leave it sitting for hours, come back, and it will do the "Entering setup..." but THAT IS IT. Any help would be fine! Thanks in advance!
  • csc86 Sep 18, 2008
    Model of laptop Compaq presario M2202 TU
    Then identifies
    CPU = Intel(R) Mobile CEleron Processor-M
    Memory (all passed System BIOS shadowed
    Video BIOS shadowed
    Tscos DVD (coorcrt)
    Mouse initialized
    laptop hang after this error.
  • Roberta Smith
    Roberta Smith May 11, 2010
    what operating system are you using ?
    Brigadier General:
  • 5,158 Answers
It may be the bios.... remove the bios battery for at least ten minutes... make sure the main battery is removed
so there is NO power to the laptop for about ten minutes
.... after you reinstall the bios battery and put the main battery back in and plug in the external power.... boot it up again.
Posted on Sep 08, 2008
  • Roberta Smith
    Roberta Smith Sep 08, 2008
    Does the screen go blank or you still have a cursor ?
  • Roberta Smith
    Roberta Smith Sep 09, 2008
    No worries.... glad we could help and if you have other problems just holler.
    and thanks for the rating
Cannot enter bios in the standard way with F2. I believe IDE controller is set to disable
Turn on your computer. If your computer is already on, then reboot it.
You need to see the initial display screen to get into the BIOS.
Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information.
The majority of Gateway computers use the F1 key.
If, for some reason this does not work, then use the F2.
All of Gateway's desktops use the F1 or F2 keys.
hope this helps
Sep 17, 2012 | Gateway GM4019E PC Desktop
Gateway Solo 9550 bios unlock password master
There isn't one, either take the laptop apart and remove the CMOS battery for 10 seconds or download and burn hiren 15 to a CD and use one of the CMOS password wipers.
Jul 12, 2012 | Gateway Solo 9550 Notebook
I have a Gateway Solo 9550 and cannot get it to come up past the blue screen. Help!
You can put the windows install disk in cd/rom and start the computer up from the disk.when asked to repair push R.. this will start in command prompt link to microsoft help. when command prompt window is up type this .......CHKDSK C: /F / enter. Do not turn off computer until check disk is done..Restart the computer..If you do not have a windows disk you can download MS-DOS portable HERE you can put on a memory stick and start computer up from usb
Oct 12, 2011 | Gateway Solo 9550 Notebook
I have a Gateway solo 9550 laptop. When I turn it on it says ERROR Invalid system configuration data- run configuration utility. What exactly is wrong? Windows boots up when I press f1. How do I stop this...
You usually gets this message when you leave the system unplugged for a long period of time. Whe the internal battery drained out the system loses the configuration data. Normally the internal battery will get recharged when you plug the power back. Just have to go into the BIOS and set the date back to the current date. In some case the internal battery needs to be replaced if no longer holds a charge.
Dec 18, 2010 | Gateway Computers & Internet
I need the size or model number for a replacement charger for the gateway solo 9550.
Compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Aug 30, 2010 | Gateway Solo 9550 Notebook
Quick question regarding the Gateway Solo 9550 laptop. I cannot connect to any wifi network. The laptop recognizes networks by name, but it does not connect. Any ideas?
Try clearing your winsock///Click start...Go to run..type cmd....Then type netsh winsock reset. Computer will say need to reboot but not nessasary
Apr 04, 2010 | Gateway Solo 9550 Notebook
I have a Gateway Solo 9550 wont boot
it seems issue is very sensitive and without taking look at it problem can not be sorted it can have multiple problems............please contact manufacturer
Sep 01, 2009 | Gateway Solo 9550 Notebook
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
Gateway Solo 9550
If you can see a faint image of the desktop or the machine works with an external monitor, the either the screen inverter or the screen backlight has gone out. Start by checking the screen connections. The connection to the screen, screen to inverter and screen to motherboard. Connections can sometimes work loose. A loose connection generally causes the screen to go out entirely, rare but occasionally it can cause just the backlight to go. If the connections are good, then you will need to take it in to have the screen and inverter tested to find out which it is. If it turns out to be the backlight, you will have to purchase a new screen, screen are considered sealed units and just the backlight can't be changed out.
Jul 21, 2008 | Gateway Solo 9550 Notebook
get a battery with a close model number
Nov 13, 2007 | Gateway Solo 9550 Notebook
Gateway SL9550-30165318 Notebook Logo
180 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
