Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
Color on the Sony Bravia
I ahve a 42" Sony Bravia and have developed a new problem. On my 'cable' channel the color is fine..it isn't HD. When I switch the set over to HD, the coloring is green and red. Is there something I can do to adjust this or does this need repair?
  • Sony Master
  • 520 Answers
Check the cables. It sounds like the cable for blue is loose.
Posted on Sep 08, 2008
I got a sony bravia kdl46nx800 led tv and for some reason, there is a green line on the right edge of the screen on certain HD channels and not on regular channels when i watch the shows. it is a common...
Hi, I can't say I've ever seen that happen with that TV before so I'd say it definitely isn't common. I'm pretty sure it's the signal from the HD channels, I'd suggest talking to your cable service provider.
May 14, 2011 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Color shift to green on non hd channels
change out your box. thats why they rent them. they anticipate your going to have issues thats why they rent them. i have gone through about 12 boxes over 5 years. change res to 1080i
Jun 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Feb 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia 40"
Do you have a cable or satellite box connected to the tv?
Dec 31, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
608 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
