Question about Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001)
I have a large house (e.g. 4,000 sq ft). Will the Powerline network work throughout my house?
    Scholar:
  • 130 Answers
While the homeplug 1.0 standard was optimized for homes of around 2000 square feet, our Powerline devices have been tested with excellent results in homes of up to 7,000 square feet.
Posted on Feb 19, 2006
Convert 264 sq ft to linear feet
Hi Mona:
I'd like to be able to help so will need to clarify the intent of your question. Bear with me while I explain.
- 264 sq ft is a measurement of area.
- Example: a room 11 ft wide by 24 feet long would have a floor area 11 X 24 = 264 sq.ft
- 264 linear ft is a distance measurement, and indicates the distance between 2 points.
- Example: A house that is 66 feet square has a perimeter of 264 linear ft. (4 x 66 = 264)
If you can take this information and apply it to your question, I should be able to give a clearer answer.
Hope this helps
Jun 11, 2015 | Heating & Cooling
My Goodman CK361D unit blows cold air from the vents and it is cold when you stand there. But it doesnt seem to push it throughout the house. we can run it for hours and it will still be over 70 degrees in...
There are alot of factors when dealing with this problem. Heat Load ( Typical A/C unit is designed with a split of 20 degrees farenheit.) If you measure the temperature leaving the discharge registers, the temperature should be around 20 degrees colder than the air entering the return air grille (Filter Location). Also your unit seems to be a 3 ton; In which this system is designed for roughly 450 sq. ft. per ton and can go as high as 550 sq. ft. on newer homes with more than adequate insulation values. On older homes with minimual insulation the 400- to 450 sq.ft. rule per ton should be observed. Another reason could be that the units needs servicing like a dirty condenser coil or evaporator coil, improper refrigerant charge, etc can all be issues that can result in your problem.
Finally, most typical units or designed to maintain a home 20-25 degrees below outside temperature. Example 95 degrees outside, inside should not be set lower than 70 to 75 degrees, and the 5 degree range depends on the SEER (Seasonal Energy Efficiency Rating/Ratio ) of your unit. Hope I was helpful in giving you some direction in things to look for to resolve your problem.
Jul 05, 2011 | Heating & Cooling
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Powerline ehernet adapter stuck in standby
1. plug out from the electricity socket and plug it in back
2. check with the electric phase because powerline adapter works only with a single phase in the house
3. a house will have different phase try connecting it in the same phase of the router.
4. or else try updating the firmware from the website for ur particular powerline adapter
Feb 08, 2010 | Powerline Ethernet Network Adapter
Belkin powerline adapter doesnt connect to internet
try resetting the adapter
if not working try updating the firmware
if not working make sure ur adapter is pluged in the same power(electricity) phase of ur house with the router
the house will have different power phase so make sure of it
both the router and the powerline adapter must be in same phase of electricity
Jan 18, 2010 | Belkin Powerline F5D4050 Network Adapter
I have an '06 model combination cooling and heatin
For every 500 sq. ft. house or a 1-bedroom size new house you need 1-ton of cool . An old house you need a ton worth of cooling for every 400 sq. ft. house or a 1-ton per 1 bedroom size house.
Dec 22, 2009 | Whirlpool Heating & Cooling
Filter for QCA Aruba xl
QCA has used 4 different sized filters in their tubs through the years.
  • c-4326 4-15/16" x 13-15/16" 25 sq ft
  • c-4950 4-15/16" x 13-15/16" 50 sq ft
  • c-4995 4-15/16" x 23-5/8" 95 sq ft
  • c-5397 5-5/16" x 17-13/16" 80 sq ft
you will need to measure the inside height and diameter of housing and see which one will fit best.
Jan 30, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Logo
174 people viewed this question
Top Efficient Networks Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
