Question about Philips CDR602 CD Recorder
DOOR FAULT Recently, when the unit is powered on, the display will immediately say "OPEN" or "CLOSE", instead of the usual "INSERT DISC". The drawer will not open so a disc can't be placed inside. I bought this recorder in 2002 and it worked fine until recently. Can this be easily repaired or should I just buy a new machine? Thanks, Alan
5 Suggested Answers
  • 86 Answers
SOURCE: cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Posted on Feb 13, 2009
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
  • 10 Answers
SOURCE: cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Posted on Jun 07, 2010
snakehead
  • 1074 Answers
SOURCE: INSERTION OF BLANK OR COMMERCIALLY
plug out the set from the current for about a hour then plug in back..if that does not help then your set needs repair..or buy a new one.good luck.
Posted on Sep 13, 2011
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
The eject button on my VRDMC5 DVD recorder does not work at all.
When idsk is not recognized it is because the laser mechanism can no longer focus on the disk. If this happens with all disks then the unit is fubar and it is time to go shopping since repair is not cost effective.
Apr 24, 2017 | Sony VRD-MC5 DVD Recorder
NAD CD 5425 - No Spin - Sometimes
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Dec 23, 2008 | NAD C521 CD Player
"no disc"
unscrew the unit try to clean the lense..this will fixya
Feb 04, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Jul 28, 2007 | NexxTech DP3222 DVD Player
Does not play CDs. After closing, tray immediately opens again and displays "Take CD out". Cycles through trays and gets stuck.
If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. If it wont help and you're NOT still under warranty you should at least open the system and look for Problems with the door opening/closing: Steps: 1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor. 2. Check for broken or loose gears and have them replaced. 3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players. 4. Use electronics-grade contact cleaner to clean the door-position contacts.
Jan 13, 2006 | Panasonic SC-AK600 CD Shelf System
Philips CDR602 CD Recorder Logo
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
